Old 05-28-2012, 05:03 AM   #1
Fresh water from tank pumped out city water hookup
I have a 2006 Salem 26 BKHS. I'm attempting to flush the fresh water tank and when I cycle the FW pump on water flows out the city water hook up and I have no pressure at any of the faucets. There has to be a check valve in the system, but where? I have traced the pump out flow line back to a "T" in the cold water system, but no inline check valve. Thanks for any ideas you can provide.
gclinton1 is offline   Reply With Quote
Old 05-28-2012, 05:17 AM   #2
fonzie's Avatar
Your city hook up should have a check valve in it. Check this post: City Water Solved
Fonzie
Old 05-28-2012, 05:41 AM   #3
Once again thanks for the help. I was able to fix it already. It appears that when the dealer winterized the unit they reinserted the screen backwards. the screen then was depressing th3e check valve and holding it off the seat. Thanks for pointing me in the right direction.
Old 05-28-2012, 06:02 AM   #4
fonzie's Avatar
You're welcome. Lots of great people out here that will help as you can see by previous post.
Fonzie
