Old 08-14-2012, 10:15 PM   #1
1cheneyj's Avatar
Fresh water gauge reads incorrect
Have a 2010 Rock Wood 8317 RKSS. When the fresh water tank is empty the information panel shows any where from 1/3 to 2/3. Is there a way to calibrate the sending unit?
1cheneyj is offline   Reply With Quote
Old 08-14-2012, 10:38 PM   #2
TURBS's Avatar
Simple answer is no
Old 08-14-2012, 11:27 PM   #3
Location: No longer own a Forest River product, but enjoy the info on this site
Based on my experience - bad readings for the fresh water tank were due to being out of "level." See that your camper is level and check the water level on the panel - this might help.
We also found that the fresh water tank "pickup" line was about 1" above the bottom of the tank. This left a lot of water in the tank - when the pump was still trying to pull water. We relocated the water pickup line to the bottom of the tank, where the drain valve is located. This allowed us to pull every last drop from the water tank before being dry.
teamgl is offline   Reply With Quote
Old 08-15-2012, 11:57 AM   #4
Herk7769's Avatar
Times a million. Almost never see fresh water tank problems that were not either "out of level" or GROSSLY contaminated with algae and slime.
Level THE TANK (you may need to pull down a piece of belly covering to see it) and check again.
DeTox your water tank with beach and flush well.
HAM CALLSIGN - KC3FFW
Old 08-31-2012, 10:31 AM   #5
lami's Avatar
Surveyor SP295
My fresh water gauge has read empty from day one! Full, half, empty doesn't matter it still reads full. Grey and black work fine. With a covered under body It's not easy to investigate.
Lami
Manitoba, Canada
2012 Surveyor
2012 - 38 Days Camping
lami is offline   Reply With Quote
Old 08-31-2012, 10:32 AM   #6
lami's Avatar
OOPS I meant to say it reads empty all the time!
Lami
Manitoba, Canada
2012 Surveyor
Old 08-31-2012, 11:27 AM   #7
Herk7769's Avatar
Empty all the time is the easiest to troubleshoot.
The ground wire is broken or disconnected.
Look at the ground probe on the fresh water tank or at the connection where all the ground probes come together (may be near the black/gray tank or behind the monitor panel).
File Type: pdf KIB Monitor Panel M21 Wireing Diagram.pdf (51.2 KB, 387 views)
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (149.2 KB, 438 views)
Old 08-31-2012, 11:42 AM   #8
lami's Avatar
Thanks Lou!
I now have a fall project! The troubleshooting guide is great. I will let you know how it works out!
Lami
Manitoba, Canada
2012 Surveyor
Old 09-07-2012, 08:20 AM   #9
Just went through correcting this problem on our trailer. Made up a pickup tube and replace the fitting at the tank outlet with the new pickup tube.
Worked out great. I know get at least 4-5 gal more out before it sucks air. Not sure why they build tanks with out sumps in them.
Dave and Marcia
2002 Ford F350SD 4X4 Crew cab Long bed, 7.3PSD Automatic
2007 Flagstaff 829RGSS (link to mod photos)
http://s251.photobucket.com/albums/g...%20its%20mods/
welove2drive is offline   Reply With Quote
