Old 10-05-2015, 05:25 PM   #1
15 -21FBRS 17-F150 2.7 e
J.Fallon's Avatar
Fresh water holding tank bracket bent
Just crawled under 2015 21fbrs. One of the Fresh water tank brackets is bent. I keep 1/3 full for our last 2 trips 2000 miles total. Guess I'll beef it up at the shop.
2015 21fbrs
2014 Ford F-150 4x4 5.0
J.Fallon is offline   Reply With Quote
Old 10-05-2015, 05:28 PM   #2
Ford Idaho's Avatar
Seems to be the issue of the year, I just put in 5-10 gallons before a trip.
Old 10-05-2015, 05:43 PM   #3
J.Fallon's Avatar
Name:	ImageUploadedByForest River Forums1444085030.979309.jpg
ID:	90758Click image for larger version
Name:	ImageUploadedByForest River Forums1444085043.744326.jpg
ID:	90759Click image for larger version
Name:	ImageUploadedByForest River Forums1444085059.011835.jpg
ID:	90760Click image for larger version
Name:	ImageUploadedByForest River Forums1444085076.347058.jpg
2015 21fbrs
Old 10-05-2015, 05:45 PM   #4
J.Fallon's Avatar
Going to support the tank cut loose original supports and weld in new ones or bolt in new ones
2015 21fbrs
Old 10-05-2015, 05:46 PM   #5
Our Work & Play had a similar issue. But we still haul 110 gallons of water to every race usually 200-300 miles. No problems at all.
KFX450RXC is offline   Reply With Quote
Old 10-05-2015, 06:21 PM   #6
MTA
We 2013 2109S with the same issue. There has been several threads with similar problems. May want to also be sure the vent line towards the top of the tank is up against the bottom of the floor. I saw a thread purtaining to this about the vent and it was also some of our problem. It was looped down and fill with water and not let the air out.
MTA is offline   Reply With Quote
Old 10-05-2015, 06:39 PM   #7
J.Fallon's Avatar
Full tank
I remember now. We went from Columbus Belmont state park to race Duquoin. I filled the tank. It was only about 2 hrs up. That probably is when it happened. 37 gal. The factory pre stamped the material so they could add cross supports and could use the same piece front or rear. Just poor design. I can fix it better than a rv tech. Hell I build race cars for a living!
Old 10-05-2015, 06:40 PM   #8
I had the angle iron beefed up and steel plates welded across the bottom of the tank on mine.
00buck is offline   Reply With Quote
Old 10-05-2015, 06:44 PM   #9
J.Fallon's Avatar
Thanks 00Buck. That's the direction I'm headed.
Old 10-06-2015, 01:22 PM   #10
It's a Warranty issue
I had the same issue on my '14 21DS. The dealer fixed it under warranty. It's ok now.
randman132 is offline   Reply With Quote
bent, fresh water, tank, water
