Old 11-19-2013, 10:01 PM   #21
Yes rivers freeze but only on top. There is still flowing water under the ice. Dad owned a car wash all we did in the winter was open a valve and let a small amount of water pass through the spray wands onto the ground. Even in 20 degree temps the running water keep the lines from totally freezing. When the valve was totally opened and let more water flow the increased water flow will get rid of any icy mixture that is in the hose. To relate this to a camper I would install a Y fitting at the rv connection point and let a small amount of water piss out. This will keep the water hose from freezing if you have a sudden cold snap. If you are a frequent cold weather camper then you should invest in a heat trace water hose.
Also, ALL the water coming down the river is close to 32 degrees, where as the water in the car wash is coming from a pipe buried below the frost line and is probably running about 55 degrees or so, so it doesn't freeze because it doesn't really have enough time to get cold before it's out of the pipe and onto the ground.
1988 Coleman Sequoia - popup (1987-2007)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 11-20-2013, 03:22 AM   #22
AquaMan's Avatar
Originally Posted by extremebike View Post
You are pumping hot water from the water heater to the fresh water tank and circulating the water to keep it from freezing the inside lines.
I think the OP's problem was keeping the water from freezing in the fresh water line "supplying" the camper. Once it's inside the unit, the heat from trailer will keep the lines from freezing, provided the unit is so equipped. On your solution it would only keep the tank and the line supplying the water heater from freezing, unless you opened all faucets, which you would eventually run out of water.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 64
fresh water, heater, water
