Old 11-14-2013, 09:01 AM   #1
BuckeyeGal
Fresh water hose heaters?
I have a 34 foot Sabre 5th wheel & an looking for hose heaters to keep fresh water line open on those last few cold nights of the season. example mid Oct this year we had snow flurries on last night out.
thnaks.
tvc
buckeyegal is offline   Reply With Quote
Old 11-14-2013, 09:16 AM   #2
extremebike's Avatar
Hi!
If it's only for a couple of nights the hardware store or plumbing supply places have a 1/2" to garden hose adapter. Unscrew your outdoor shower head (1/2") screw on the adapter and then to your white fresh water hose and turn on the hot water. A couple of tanks of hot water should see you through a couple of nights.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 11-14-2013, 09:24 AM   #3
abjb's Avatar
We just bought one of these, they come in different lengths.
Shop EasyHeat 6-ft 42-Watt Pipe Heat Cable at Lowes.com=
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 11-14-2013, 09:30 AM   #4
Originally Posted by abjb View Post
We just bought one of these, they come in different lengths. Shop EasyHeat 6-ft 42-Watt Pipe Heat Cable at Lowes.com=
If you look it says that it's for rigid pipe only and never to use it on hose.
Old 11-14-2013, 09:50 AM   #5
Camper Less Camping
Cajun Po-Boy's Avatar
thnaks.
tvc
This is what you need to purchase...do an eBay search for heated RV fresh water hose...many to choose from
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 11-14-2013, 10:03 AM   #6
abjb's Avatar
I wonder why, I've seen a few in parks???
I'm using it around a 1" rod buried beside our fish pond
2012 Georgetown 360
Old 11-17-2013, 05:25 PM   #7
Jimmerinwi's Avatar
If your on a full hook up site, open your gray tank and let the water in the bathroom trickle. I'm on a perm site in northern Wisconsin and this time if year that's what I do to keep the hose from freezing.
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 11-17-2013, 05:37 PM   #8
You are correct running water want freeze. If you notice car washes are set to let water trickle from the hoses in freezing temperatures.
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 11-17-2013, 05:52 PM   #9
phat phrog stunt crew
Have seen the mississippi river freeze, and that water is flowing.
dwaynerz is offline   Reply With Quote
Old 11-17-2013, 06:28 PM   #10
BarryDO706:
Don't know where you saw this. The most I saw on the Lowe's site was "Cable must be installed straight on pipe." This really means, "don't wrap it around itself." I never saw the words "rigid" or "hose."
Here's the manufacturers brochure, also doesn't say "not on hose." Just says OK on plastic or metal pipe.
http://www.emersonindustrial.com/en-...ochure_web.pdf
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
fresh water, heater, water
