Old 07-17-2016, 01:36 PM   #1
Fresh Water Pump
Where is the fresh water pump in a 2014 Micro Lite 21FBRS, and does it have a 30 amp in-line fuse? I used in only once when I first bought the RV in March 2015. I filled the fresh water tank today and pushed the water pump switch; I did not hear the pump working nor did any water flow from the faucets. I live in Corpus Christi, Texas, so I did not winterize. I would appreciate any assistance. Thanks!
Hector517 is offline   Reply With Quote
Old 07-17-2016, 04:33 PM   #2
bikendan's Avatar
Usually in a cabinet, behind a false door.
Equalizer WDH
Old 07-17-2016, 04:40 PM   #3
MNtraveler's Avatar
The pumps run on DC power, not AC, using power from the DC battery or batteries. That way they can be used when you are not connected to AC, such as boondocking. So look for a DC fuse out, or else loose wires or a loose ground connection.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 07-17-2016, 04:45 PM   #4
raspivey's Avatar
I had a 2014 2104S...same trailer, different floorplan. Water pump should be in the passthrough storage on the forward wall, drivers side. I don't recall a fuse other than the one in the fuse panel. Are you plugged in to 110V? If not, your disconnect might be off.
fresh water, pump, water, water pump
