Old 10-28-2018, 03:41 PM   #1
Fresh water pump
Never used my fresh water pump on any of my campers. Needed this past weekend. Fresh tank is 2/3 full, pump runs non-stop.
Let run for over an hour this afternoon, only getting a trickle of flow.
Any ideas?
JBurr is offline   Reply With Quote
Old 10-28-2018, 03:43 PM   #2
ejohnson1144's Avatar
Any ideas?
Check your low point drain and outside shower if you have them
ejohnson1144 is offline   Reply With Quote
Old 10-28-2018, 03:45 PM   #3
Mr. Dan's Avatar
Check to be sure your winterizing/anti-freeze induction valve is set to draw from the fresh water tank and NOT from an anti-freeze bottle.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 49
Old 10-28-2018, 04:04 PM   #4
Just as confused as you
Scrapper's Avatar
Check the filter on the input side of the water pump. It could be loose, have a leaky o-ring, or a small crack.
Richard & Jill
Camping since 1989, seasonal since 2000
fresh water, pump, water, water pump
