Originally Posted by Charles Firth
The power light comes on but just does not activate the pump.
That light just means you have power to the switch and to the terminal that the wire to the pump is attached to. Now one just has to determine that the power has a path to the pump and one to return to the battery (Neg/Ground).
I have found that ground connections, especially those that are connected to a common wire, are often the culprits. Either rusty/corroded connections to chassis or broken loose inside the giant crimped connectors holding half a dozen ground wires. Be sure and check the crimped connectors on single wires too. People in a hurry to finish wiring often don't check to see if it's done right.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
