Old 11-13-2015, 01:28 PM   #11
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by whisperwhillow View Post
...went to get a drink of water and noticed that it tastes a bit funny ...Anyone else had this happen?
Yes. It was the hose itself. Not all water hoses (white, w/wo blue stripe) are created equal.
I agree with the others. Sample water at 1) spigot 2) end of hose where it attaches to trailer 3) nearest-to-water inlet faucet 4) furthest faucet. Work down the line from the source.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 11-13-2015, 02:00 PM   #12
clr
It may be your hot water heater that needs to be drained, but if that is the case the hot would smell much worse than the cold water. It also my be water that has been trapped in a water line for some time that is causing this smell. Ensure that you run some water from all the faucets, Do not forget the cold and hot water if equipped for a washer in a closet normally, this is a common source of the problem.
clr is offline   Reply With Quote
Old 11-13-2015, 06:37 PM   #13
Chuck.C's Avatar
I had a similar experience. Turned out that the water filter (built in) was the culprit. I opened it and it was black with goop. All water coming in goes through it. I pitched the cartridge, cleaned the case and all was well.
2013 Coachmen Mirada 35DL
Chuck, Susan, and dogs- Gracie the Registered SnackHound and Toby the Wonder Boxer
Chuck.C is offline   Reply With Quote
Old 11-13-2015, 06:59 PM   #14
I had that problem one time. It turned out the connecting hose to the trailer was bad. I could only guess the hose separated internally and it was dedicated water hose.
elmerfulmer is offline   Reply With Quote
Old 11-13-2015, 07:50 PM   #15
I know this may not be the answer but, some of the towns have stopped using chlorinated water. They did this here in Junction and out of the tap the water tastes fishy, I in my home use a RO unit just to drink this putrid liquid they substitute for water.
szabla is offline   Reply With Quote
Old 11-14-2015, 09:19 AM   #16
Wolverine 1945's Avatar
Not sure it would help in the future,,, But I would use an in-line filter,,,
along with unit filter !!!
Wolverine 1945 is offline   Reply With Quote
Old 11-14-2015, 09:55 AM   #17
Good morning, folks!
Woke up this morning to a pretty chilly Colorado morning, went to get a drink of water and noticed that it tastes a bit funny and smells like the liquid stuff I put into the tank after I empty it. My water supply is coming from the city water hookup right now. My first thought was that something froze and busted and now the fresh and gray lines or tanks are commingling.
I also might mention that my body hurts and I've been throwing up all night. Could this be coincidence and I've simply caught what my son had a couple of days ago? Sure. It could. But I thought I would mention it.
I don't see any way your grey and fresh water can possibly mix so I wouldn't worry about that. You do not say if you are using a white water supply hose. If not you need to get one. As suggested disconnect your hose from the trailer and check it, If it is ok then the problem is in the trailer. If not then disconnect the other end and check to see if the waer being supplied to you from the cg is ok. If not good contact the cg, if it is ok then you have a bad hose so get a new one.
If the problem is in the trailer you need to check your water filter. A question, when was the last time you sanitized your water system? If you don't know then it is possible you need to do it. Use a cup of bleach and about 10 gallons of water to your fw tank. Turn on your fw pump and open all your faucets, cold and hot. If you have an outside shower don't forget it. Smell the water at each faucet and close it when you smell bleach. Now drain the fw tank and flush it out with fresh water. Open each faucet till you no longer smell the bleach, then drain the fw tank and shut off the pump. You have now sanitized your fw system. You can now hook up your fw hose to the trailer and it should be ok.
There are not many things that can cause your problem. City water supply, fw hose, filter and system needing to be sanitized.
Another thing you may want to do, which I do. I have a portable Britta water filter and filter all my drinking water thru it. I keep the pitcher in the fridge so I always have ice cold drinking water that is double filtered. First thru the trailers filter, then thru the Britta filter. You never know the quality of the water the cg is supplying.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 11-14-2015, 10:15 AM   #18
X2 on the Refrigerator Filter,,, we use a PUR made to fit in the Fridge !!!
Old 11-14-2015, 10:25 AM   #19
Love RVing
We took the water filter off and put 1/4 cup of bleach in it, then reinstalled and it cleaned our odor problem. Changed filter for new one next day.
burse is offline   Reply With Quote
Old 11-14-2015, 10:34 AM   #20
Both the Pur and Britta are nice filters. I like the two quart pitcher that the Britta filters into. As I drink a glass of water I filter another glass so the pitcher stays full. Never have to touch the filter till you change it every few months, or 300 bottles of water. That's a lot of water for one person and one dog!
Jim
George Bernard Shaw
fresh water, water
