Old 09-27-2016, 01:15 PM   #11
woodyrock1's Avatar
Originally Posted by DaveJordan View Post
I think the OP was hooked up to city water - so there was positive water pressure (and available flow) on the inside-the-rv side of the pump.
Dave
Makes sense, I am now seeing and understanding how this can happen now
2005 Ram 3500 Cummins Dually
2014 8280WS Rockwood Signature Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights
woodyrock1 is offline   Reply With Quote
Old 09-27-2016, 01:16 PM   #12
wnelsonfl's Avatar
I had this problem until I bought a water pressure regulator. Don't buy a cheap one. Camping world has one for about $50 that solved my problem. I paid $10 for one that didn't work. The last campground I stayed at warned you about the problem.
Warren
2014 Silverado Z71 4x4- 5.3
Flagstaff 21 FRBS
235 nights camping this past 30 months
31000 miles
wnelsonfl is online now   Reply With Quote
Old 09-27-2016, 01:52 PM   #13
rracer5's Avatar
This topic comes up a lot here and there have been many, many examples of the same thing happening. Your symptom/problem is not unique.
The on-board water pump has a check valve built into it (for this very reason) to keep the city water from back filling the fresh water tank when connected to city water.
Sometimes, when using the on-board pump, debris or dirt can lodge in the check valve holding it partially open. When the pump is shut off and water supply is reverted back to the city water, it will flow back through the stuck opened check valve and fill the tank.
This scenario can also happen if you happen to run the pump while on city water where the city water pressure is much greater than the water pump's output pressure. When you turn on the pump, it will force open the check valve but the city water's greater pressure and flow will force water back into the fresh tank, through the now-opened check valve once the pump is shut off.
Usually to cure, all you need to do is turn off the city water supply, crack open a faucet to relieve pressure, close the faucet, turn on the water pump, re-open/close a faucet a few times and allow the pump to cycle to rid the check valve of any debris. Turn off the pump, crack the faucet to relieve pressure again, close the faucet and turn city water supply back on.
Sometimes the valve can not clear itself on its own and disassembly of the pump (or replacement) is required.
Many folks have installed an in-line check valve near the pump outlet to cure the problem as well.
This complaint is one reason I never leave my rig for more than a few hours without shutting off the city water supply. And, if I am going to be hooked to city water for long periods of time, I will open my fresh water drain valve so if the check valve fails, it won't over fill the tank and bulge it or blow the drain line off.
I agree with all the above but,......if the city water pressure is greater than the water pumps low pressure point (the point where the pump would turn itself on), the pump would have no need to and shouldn't run at all.
And, here's a new scenario I came across a few weeks ago. We initially set up and DW used some water from the fresh water tank before I hooked up hose to the CG's city water connection. I never turned off the water pump (forgot). A little later, I went to add chemicals to the black tank through the commode & when I flushed, I heard the water pump run. I ran another faucet and although a steady flow, the water pump didn't run. So, I guess this is a good feature for those times when the CG's water pressure is low. The only thing I don't know is.....did the water pump just "boost" the pressure of the CG's supply or did it supplement the CG's deficiency by also pulling water from my FW tank?
EDIT: This is why I always carry 1/3 tank FW all the time. Just in case the CG's system should go down.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 09-27-2016, 04:33 PM   #14
JnB
Smile Solera 24R yearly mntce
There should be a check valve on the inside-the-camper side of the water pump. Water could leak back past the water pump, into the tank, if the check valve is missing or defective.
Dave
Reaching out to another Solera owner...and just maybe an old friend from Tucson (formerly colleagues in medical administration). As to the Solera question, we have a 2016 24R now approaching one year. With the original purchase, we were granted a yearly mntce. Freedom RV in Tucson has done a great job with the little electrical fix its and all is working well. Our mileage is at about 6000 so we don't need an oil change. No leaks, a few squeaks, but no problems we know of. What should we ask for as a year end check?
Dave, do we know each other from the medical field? I'm Barb Smith, dermatology and later primary care.
JnB is offline   Reply With Quote
Old 09-27-2016, 04:58 PM   #15
Usually Confused Member
emm-dee's Avatar
What you're describing seems to be a "normal" problem. As others have mentioned you can probably fix it using the following procedure (plagiarized from another thread and saved in iPhone notes app):
Water Pump Check Valve Reset
Turn off city water
Turn off water pump if on.
Turn on any faucet wait 1 min
Turn on water pump
let water run 1 min
Turn off faucet
turn off water pump
Wait for water pump to quit running
Turn on city water
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 09-27-2016, 07:49 PM   #16
Pickin' & Campin'
The pumps pressure switch is on the pump side of the check valve. If the check valve was working correctly, the city water pressure would have no effect on the pressure switch and by turning on the pump, it could run momentarily causing the check valve to open and then the higher city water pressure causes back pressure which can hold open the check valve and fill the tank. I've seen it happen. Granted, conditions have to be right but it happens.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
2017 Ford F-Series SCREW 4x4
Days Camped: '15=22 '16=46 '17=30
Old 09-27-2016, 07:58 PM   #17
Pickin' & Campin'
Also, rracer5, in your new scenario, the pump supplemented your water supply from your fresh water tank.
Old 09-27-2016, 08:24 PM   #18
Flybob's Avatar
Do this. Don't recommend you have water pump on when connected to city water.
Turn off city water
Turn on water pump
let water run 1 min
Turn off faucet
turn off water pump
Turn on city water
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-27-2016, 08:48 PM   #19
Blackhat6mike's Avatar
Make sure your hot and cold knobs on the outside shower [if you have one] are turned off. If one is left on, it can flow back into your freshwater tank.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 09-28-2016, 06:13 AM   #20
Pickin' & Campin'
How is that possible?
That could cause cold water to mix with hot water (resulting in warm water at another tap instead of hot and only if both were on and the shower head closed) but I don't see how it could fill the fresh water tank? Wouldn't the outside shower simply leak if one of the knobs were left on?
fresh water, storage, water
