Old 06-10-2011, 09:48 AM   #11
MovinSue
MovinSue's Avatar
This is "sorta" related:
My FW tank swallowed the 7" end plastic hose from my FW Fill hose accessory. The fill tank accessory is a little add-on piece that screws onto your fresh water hose--has a switch to start/stop water flow into the tank and guides water into the tank--about $4 at CW. The clear plastic hose piece recently came apart from the rigid plastic "business" end. I cannot see it or reach it with my fingers so it's either lodged somewhere in the neck or dropped down into the tank.
Anyone have any experience with this; will the hose provide a breeding ground for growth of undesirables or get in the way of any working parts? Does it require intervention or is it a non-problem?
"Some say that wine improves with age...I say that age improves with wine"
2013 Lacrosse 323RST TT
Towing Cassie the Dog, a privileged Bichon frise
Winters in FL--Summers in Northern CA
MovinSue is offline   Reply With Quote
Old 06-10-2011, 11:15 AM   #12
If it's just a small hollow tube I wouldn't think it would cause much trouble in the fresh tank. It shouldn't clog anything, and when you sanitize the tank it would be sanitized as well.
brianb is offline   Reply With Quote
Old 06-11-2011, 09:41 AM   #13
MovinSue
MovinSue's Avatar
Thanks for your opinion. I suspect it will not create havoc and bedlam but always like to have another great mind weigh in. Nothing like this ever happened to my equipment before and I have never read of it in other Forums--so it is reassuring when other experienced RV'ers think it will not be a problem.
