Old 01-14-2013, 05:05 PM   #1
Fresh water tank
Ok everyone I have a question. I'm going on a 300 mile trip and i've been told that I need to wait and fill me fresh water tank when i get their due to it would hurt the tank. I've also been told that it's ok to fill the tank and travel with is full. The problem is they dont have water there. can someone please help me?? Thanks
JBAR is offline   Reply With Quote
Old 01-14-2013, 05:12 PM   #2
TURBS's Avatar
Can you get water in the town before?
Don't know why you couldn't travel with water but why haul the extra weight.
In some cases a full water tank may overload your hitch weight or be over gross.
Seems most people run on the edge of tow capacity as it is and 35 gal of water will weight over 240 lbs
Turbs
Old 01-14-2013, 05:14 PM   #3
mike06081969's Avatar
You can travel with your fresh water tank filled. It will add several hundred pounds to the weight you are pulling, and if you only partially fill it, it may cause 'chocking' to some degree as the water sloshes back and forth in the tank. I prefer to travel with my fresh water tank empty just so I'm carrying less weight, but I don't dry camp, either.
Mike in Tennessee
Former 2 time FR owner
2007 Crossroads Cruiser 30QB Fifth Wheel
2008 F-250 Lariat 4x4 6.4 Powerstroke
Firestone Ride-Rites w/cab control
mike06081969 is offline   Reply With Quote
Old 01-14-2013, 06:11 PM   #4
Herk7769's Avatar
I have seen photos of fresh water tanks with absolute minimum supports. A full tank of water could cause you trouble.
My Flagstaff had a plywood support and I would have no trouble traveling (and have done so to a campsite with no services for the weekend) with it full.
I would "take a peek" and look at how yours it is secured.
Name:	Horst Probe Install 021.jpg
HAM CALLSIGN - KC3FFW
Old 01-14-2013, 08:00 PM   #5
bikendan's Avatar
we almost always travel with a full tank. unless you have some hinky supports under your tank, there's no reason why you can't.
we prefer to have our home water to use first.
plus that barn door front of the trailer will affect your gas mileage way more than the extra weight of the water.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-14-2013, 08:00 PM   #6
Dave_Monica's Avatar
You didn't indicate what you're towing, but the impact of a full water tank may have a dramatic effect on the tongue (or pin) weight depending on the size of the tank and where it's located.
Dave
Old 01-18-2013, 10:32 PM   #7
Ret E-9 Anchor-clanker
donanddona's Avatar
Most camp sites or camp areas have water available when entering the camping area. Normally close to their dump site, why near the dump site I DON"T KNOW.
donanddona is offline   Reply With Quote
Old 01-18-2013, 10:39 PM   #8
Herk7769's Avatar
I would be careful using a water spigot located at or near a dump site. Most (if not all) have labels saying "non-potable" and is to be used only for flushing the area if there is a spill, flushing out your sewer hose prior to putting it away, and hooking up to your Turboflush (NEVER for drinking).
For those who may not know what that means non-potable means the water is either bad (poisonous), or contaminated (do not drink ever), or not tested for human consumption but assumed bad.
Most campgrounds that have dump stations have their fresh water spigot some distance from their dump area and labeled "fresh water" or "drinking water."
