Old 09-13-2015, 08:32 PM   #1
Chillbilly's Avatar
Fresh Water Tank Drain
I have a Rockwood 8244WS Ultra-Lite 5th wheel, same as a Flagstaff Classic Super-Lite 8524RLWS. I cannot find the fresh water tank drain valve. I have looked everywhere. I have tried the low drain valves but those do not drain the fresh water tank. Please help me find it!
Chillbilly
2013 Rockwood Signature Ultra Lite 8244WS
2015 Ford F250 Quad Cab w/6.2 Engine
Chillbilly is offline   Reply With Quote
Old 09-14-2015, 07:06 AM   #2
Chillbilly's Avatar
Can't someone help me - I'm desperate!!!!
Chillbilly
Old 09-14-2015, 10:05 AM   #3
DaveSchwartz's Avatar
Sorry - I don't have that model.
On mine (which is a longer wheelbase version of what you have) the FW drain is on the opposite side from the fill and is a spigot-type valve that you turn like on a free-standing, blue, camping water jug.
On a previous TT that I had with a FW fill over the tires (like yours), it was a short, capped pipe hanging down between (and inboard from) the tires on the same side as the fill.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-14-2015, 10:35 AM   #4
Gripper's Avatar
Not sure if you found it or not. I have a FR flagstaff classic lite 30ft. Mine is as well a white spigot type valve is underneath trailer and is approx. 2 feet towards the rear of the trailer from the waste dump valves. Small white handle simply moves side to side.
Essex County
Southern most area in Canada
2015 F150 XLT Sport 5 ltr V8
2011 Flagstaff classic 31.5'BHDS
Gripper is offline   Reply With Quote
Old 09-14-2015, 11:29 AM   #5
satdog01's Avatar
Try opposite side from fill location. Should be valve underneath the fresh water tank. If slide is out on some models, the valve is under the main part of trailer under the slide.
Marriot II on Wheels 2017 Flagstaff Classic 832OKBS Diamond Pkg
2013 GMC Denali crew 6.6L 2500 HD DMAX w\Alison Trans
Pepper 🌶 Pomeranian rescue 204 nights as camping buddy
Days camped in FR, 2011 = 20, 2012 = 57, 2013 = 59
....2014 = 39, 15 = 52, 16 = 77, 17 = 81, 2018 = 4
Retired :
satdog01 is offline   Reply With Quote
Old 09-14-2015, 02:30 PM   #6
Chillbilly's Avatar
Thanks to everyone who replied and also to Forest River staff. I did find it. It is under the dinette slide room on the opposite side from the fresh water fill. It's a little hard to see when the slide is open. I just assumed it would be located under the tank. Thanks again. You all saved me from hauling 300 lbs of water around.
Chillbilly
Old 09-14-2015, 02:45 PM   #7
Nothing wrong will hauling 300lbs of water around as long as you take that into account to stay under your GVWR. Since it looks like your FW tank is directly over the axles, it won't change the pin weight. My FW tank is all the way in the rear so it actually takes away from pin weight. I do it when going to a park with no water fill and sometimes even when going to provincial parks where it is just more convenient than the central water fill or taps.
Old 09-14-2015, 04:05 PM   #8
grandmapaula's Avatar
Ours is a Lexington Motorhome, altogether different I know. But ours is under the bed. You have to lift the bed, it's near where the fresh water runs in, hard to see valve. We've threatened to change that many times but just keep putting up with it. You might check near where your fresh water comes in for a hidden valve.
grandmapaula is offline   Reply With Quote
Old 09-14-2015, 04:14 PM   #9
Spigot
We have a FR Rockwood. It's a white spigot underneath on ours.
lindalees818 is offline   Reply With Quote
drain, fresh water, tank, water, water tank
