Old 07-12-2016, 01:30 PM   #1
Fresh water tank drain piece
We always drain the tank at the end of a trip, by pulling UP on the "T" for the drain. Pushing it back in - as we were ready to fill the tank - the "T" broke. This is a picture of the piece that broke off.
Does anyone have any ideas for replacing?
TT model 26RKS
Joe & Sue - Camp Mutt Dazey
2008 Flagstaff Super Lite 26RKS
2008 Ford F-150
hotzfamily is offline   Reply With Quote
Old 07-13-2016, 12:23 PM   #2
Anyone?
I've searched Amazon, Google, no luck at finding this piece anywhere!
2008 Ford F-150
Old 07-13-2016, 12:30 PM   #3
jtstromsburg's Avatar
If it's the piece on the end of a threaded rod, any camping store should have one. Like this maybe?
LASCO RV311 Replacement Valve Handle https://www.amazon.com/dp/B00ITPJX9W..._uQNHxbQYH9SQC.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-13-2016, 12:38 PM   #4
Ford Idaho's Avatar
Is it set up like this?
Old 07-13-2016, 03:06 PM   #5
Not threaded, but thanks for the reply!
2008 Ford F-150
Old 07-13-2016, 03:07 PM   #6
Similar --- Are these universally sized?
2008 Ford F-150
Old 07-13-2016, 05:33 PM   #7
Ford Idaho's Avatar
I am sure it is/was a mad stroke of luck that the RV industry uses standard size fittings for the most part.
The picture I posted was from a Winnebago site but there was no information on where to get them.
A couple of 90 degree elbows and a couple of 1/2 inch ball valves with some fittings you could replumb it easy enough.
Lowes or Home Depot will have what you need.
Old 07-14-2016, 12:49 AM   #8
They will have PEX valves, use them, not PVC.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 07-15-2016, 04:55 AM   #9
DouglasReid's Avatar
x2
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 07-17-2016, 04:36 PM   #10
Use Shark Bites
Buy Shark Bite Connections for the pex pipe in your camper. It makes it easy and quick to repair and replace. They are expensive, but they work, and are reusable, which is sometimes very convenient. Then you can use quality ball valve that won't ever break.
mnoland30 is offline   Reply With Quote
water tank, water, drain, fresh water, tank
