Old 01-19-2014, 08:18 PM   #1
Brush's Avatar
Fresh Water Tank Drain Valve Replacement
Has anyone replaced the drain valve on the fresh water tank? We have a 2009 Rockwood 8319 and the drain valve handle has broken off making it difficult to open and close the valve. Both Camping World and our local RV dealer sell a universal drain valve but it doesn't fit our model.
Bill and Darlene
2008 Tundra 5.7, 4.30 axle, 8' Bed, 4WD, Super Springs
2009 Rockwood 8319SS Reese WD hitch
Nights camped in 2018(0) 2017(25) 2016(31) 2015(34) 2014(37) 2013(36) 2012(37) 2011(21) 2010(48) 2009(33) 2008(18)
Brush is offline   Reply With Quote
Old 01-20-2014, 12:08 AM   #2
Post
On my previous TT, I replaced the freshwater tank drain with a brass house type unit. It was the 1/4 turn open/close type. It mounted on a bracket below the skirting on my unit. I got it at Home Depot. All you need is the drain spigot and the brass barb that screws into the backside of it that goes into the tubing from the tank. If yours mounts to the side of your unit and not below it, I don't think this replacement would work for you.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
drain, fresh water, replacement, tank, water, water tank
