Old 03-31-2016, 08:34 PM   #1
Question Fresh water tank filling itself when connected to city water Help!
I know this sounds bizarre but i have been hooking up to city water for over a year and only use the water pump when traveling down the road when not hooked up to city water for things like flushing the toilet, etc. Last night and again tonight we pulled into an RV park, turned off water pump on panel, and hooked up to city water. Fresh water tank was about half full. Went out later and FW tank had filled to capacity and water was coming out the overflow. There is NO water hose going into the FW tank fill hole! Water pump is OFF! Water at fawcets is coming from city water as we have the Hose hooked up from park source going into the labeled City water entry point on the RV. I can not for the life of me figure out how that darn tank is filling up. Is the a switch or lever that could have gotten turned in error. This is driving me crazy! HELP!
Marilyn & Gene
2013 FR Berkshire 400Q
FreeBird is offline   Reply With Quote
Old 03-31-2016, 08:52 PM   #2
99% chance that the check valve is stuck in the water pump allowing the city water to backfill the tank through the pump. Disconnect the city water and run the pump for a while. It may reseat the check valve. I just went through this and ended up installing a shut off valve on line out from the pump.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 03-31-2016, 09:06 PM   #3
Mr. Dan's Avatar
Originally Posted by FreeBird View Post
I know this sounds bizarre but ....
No, it doesn't sound bizarre to some of us. It actually gets reported 5-8 times per week. Many times Teamfour's "run pump" process works; sometimes people install Teamfour's cut-off valve; sometimes people jump up and buy a new pump without further diagnosis; Uncle Gene had a back-flow-preventer installed in his line.
BTW, welcome to the forum. We lived in Highland Village and Lake Dallas before we moved back to the country near Sherman.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 03-31-2016, 09:14 PM   #4
Team four has this covered! Freebird,did you have your City water "Incoming Pressure Regulator" set and installed? Youroo!!
Old 03-31-2016, 09:48 PM   #5
Yep....always use the regulator!
Old 04-01-2016, 11:22 AM   #6
I had the same problem a few weeks ago.dealer found the 4 way selector valve (city/tank/normal/winterize) had broke.they replaced it and things are good now. but most often I hear it's a check valve in by the water pump.
Mark1 is offline   Reply With Quote
Old 04-01-2016, 11:24 AM   #7
I also recently bought the "Real' water pressure regulator that is adjustable.I set it for 50# and showers/washer and toilets seem to work much better. Worth the $50.00
Old 04-01-2016, 11:54 AM   #8
Blog: RVroadtripper.com
hbillsmith's Avatar
I experienced this same problem the last few days of a long trip last month. I'll be trying the various solutions next time out and if it doesn't help, my unit is under warranty, just didn't want to take it in to sit at the dealer. Might call FR and ask to have them ship me a new pump. One thing I did notice when I peeled the storage wall back to get to the pump is that road shakes and bounces seemed to have bounced the pump enough that the screws holding it down are stripped out. My first thought was "oh well, time to stick a mouse pad under there for the noise" but now I'm thinkin' that pump looks like a pretty easy swap. In the meantime, I have a 50gal fresh tank and as much as I hate to waste water, I can always open the drain before it overflows.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 04-01-2016, 11:58 AM   #9
mdstudey's Avatar
I am taking my Grey Wolf in for the same problem. When I stopped by and talked to the service guys at the dealers, one said he had not heard of that before (huh ). I told him that it is a common problem reported on RV forums, he asked the other guy and he said it is a common problem especially with a certain pump manufacture. I did not catch the name.
Chuck & Denise + Pata a.k.a the cg Gladys Karvitz
He is a Master Naturalist She is a quilter and RV Guru
2
008 Dodge Ram 2500 TX Edition2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights2018 The great adventure planned and will be rolling soon.
mdstudey is offline   Reply With Quote
Old 04-01-2016, 12:20 PM   #10
The first time we took a trip in our new FR3 30DS the same thing happened to us. The solution for me was to take the water pump apart and found the check valve had debris in it from when the unit was built. Cleaned it out and it works fine now. Simple if you are handy.
fedatty is offline   Reply With Quote
fresh water, tank, water, water tank
