Old 07-14-2015, 10:16 AM   #11
We had the same overflow problem last August while at the FR international rally. I'd noticed that the water pump had been running a bit every few minutes and had suspected that the check valve was bad. The overflow confirmed that the valve was leaking. It's cheaper to replace the pump than to have an RV repair facility rebuild the pump and FR just installed a replacement before the end of the rally.
Phil
pmsherman is offline   Reply With Quote
fresh water, tank, water, water tank
