Old 02-22-2016, 11:54 AM   #11
redcloud1's Avatar
Sounds like the bypass for antifreeze is still trying to sucks antifreeze. Flip the valve.
redcloud1 is offline   Reply With Quote
Old 02-22-2016, 12:56 PM   #12
Same thing happened to me last year, while on a four day vacation. Had to carry water in to flush the toilet, and drink only bottled water. After coming home, I unscrewed all the filters from the taps..and VOILA!! I had plenty of water..! I wouldn't have believed thay would all get clogged at the same time...rinsed the filter screens, no more problem.
Dkerr5377 is offline   Reply With Quote
Old 02-22-2016, 01:36 PM   #13
Thanks all. Still not sure about the fresh water pump thing but I fixed the city water issue.
This whole deal speaks volume for Forest River. We work in the oil fields. We move often and have lived in this RV (408 REDS) for over 3 years now. Zero issues so far. I'm sure the pump thing is something easy I'm overlooking. The RV tech will be here tomorrow to figure it out.
Thanks again.
kdc1899 is offline   Reply With Quote
Old 02-22-2016, 03:46 PM   #14
Stormrider151's Avatar
We never use the FW tank but we did try it once. Had the same problem. Ours was algae had formed in the tank and was blocking the hose to the pump. Since your full timing it's probably not your problem but just a thought.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 02-22-2016, 06:25 PM   #15
I had a pump that sounded like it was working one time. All said and done the impeller failed
gunpro is offline   Reply With Quote
Old 02-22-2016, 07:08 PM   #16
Water pump
Hopefully someone can learn from our water issues. The first time the pump would run and not go off it was the small filter next to the pump. We removed it and cleaned it and it worked fine. The second time same issue. The pump would run, no water. After trying other things my husband saw the winterized handle outside had been turned accidently. The water flowed fine. Good luck!
Safirt is offline   Reply With Quote
Old 02-23-2016, 12:44 AM   #17
SYE
SYE's Avatar
Thanks again.
Let us know what the problem is for our future posts.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 03-19-2016, 05:24 PM   #18
USN Desert Storm Vet
Send a message via Skype™ to bfhammer
Where are the pump and winterization valve located? I've only owned my 5th wheel 3 days so I am pretty much new at everything.
bfhammer is offline   Reply With Quote
Old 03-19-2016, 05:30 PM   #19
Ford Idaho's Avatar
The valves will be on the back side of your unit.
Locate the water heater from outside, now go inside and look to where the backside should be located.
You may need to remove a panel that is screwed on to get to them.
With some water in the fresh water tank turn the pump on and listen for it, you may need to turn a faucet on for it to run long enough.
Old 03-19-2016, 08:29 PM   #20
Thank you.
fresh water, pump, tank, water, water tank
