Old 06-05-2016, 02:27 PM   #1
Bubbamace's Avatar
Fresh Water tank leaking at threads to drain hose
Does anyone know what type of sealant to use for the threads at the bottom of the tank where a plastic threaded fitting goes? I have a small leak there and it appears that the threads are damaged and stripped which don't allow me to tighten down the fitting. I'm hoping a sealant will seal the threads. Any suggestions would surely be appreciated.
Bubbamace is offline   Reply With Quote
Old 07-28-2016, 10:23 AM   #2
Canadian eh'
I've got a leak as well. I'm not too sure if it's right at the end cap or up higher and is running down to the end cap. I'll probably try to get a closer look this weekend. If it's at the end cap, I'll replace it and put a valve on there. I've got a Cherokee Grey Wolf.
Mine is more of a drip then a leak. Drips every second or two. The picture shows the moment that its about to drip
2016 Cherokee Grey Wolf 22RR
2015 Dodge Ram Sport 1500
2013 Suzuki King Quad 750 Snorkel/Rad Relocate
Fusionak is offline   Reply With Quote
drain, fresh water, leak, tank, water, water tank
