Old 01-27-2016, 12:41 PM   #1
Fresh water tank not filling
I have Sabre 291bhts and the fresh water tank is not accepting the anti-freeze. I have owned this unit for several years and winterized every year with the same process of adding the pink stuff through the fresh water fill but for some reason this year it seems that all the anti-freeze is staying trapped in the full line and not making it to the fresh water tank. Any suggestions on what may be causing this?
kodiak75 is offline   Reply With Quote
Old 01-27-2016, 12:45 PM   #2
TURBS's Avatar
Not sure why you'd want to even use the fw tank?
Install a winterizing kit .
You'll use way less antifreeze and faster.
I installed my winterizing kit on my Sabre in less then 30 minutes.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-27-2016, 12:48 PM   #3
TURBS's Avatar
http://www.rvautoparts.com/Camco-Pum...2OGxoChMfw_wcB
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-27-2016, 08:16 PM   #4
Thanks for the reply. I have purchased one and will install. My concern is that when its time to fill the fresh water tank with water for camping, the tank won't fill. Any suggestions on why the tank won't fill?
Old 01-27-2016, 08:20 PM   #5
Ford Idaho's Avatar
Have you tried to put water in it?
How many gallons is it?
Gravity feed or pressure fed?
How many gallons or antifreeze did you use?
Did you run the pump and put some A/F in the water heater?
Old 01-27-2016, 08:32 PM   #6
The tank is a 47 gallon gravity fill. I filled the tank in August for some boondocking at the Bristol race and it filled and worked fine. I drained water heater and bypassed it during winterizing process in October but the tank would not fill, even after adding about 3-4 gallons of anti-freeze.
Old 01-27-2016, 08:42 PM   #7
TURBS's Avatar
You sure it isn't full ?
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-27-2016, 08:54 PM   #8
Positive! I opened the fresh water drain on the bottom and hardly any fluid drained from tank. I also inserted clear tubing down the fill line and when I removed the clear tubing from the fill line, it had anti- freeze on the clear tubing. Maybe I have a kink in the fill line but with the covered underbelly it's hard to see if that is the case. The camper is in storage about 30 minutes away. I may just wait until spring to remove underbelly and investigate further.
Old 01-27-2016, 09:07 PM   #9
TURBS's Avatar
Did you try to stick a wire up the fw drain tube?
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-27-2016, 09:20 PM   #10
I have not. Is there a check valve that would keep the fw tank from filling? I did apply air pressure to the screen above the fill access to be sure there wasn't a blockage there.
Old 01-27-2016, 09:38 PM   #11
Blackhat6mike's Avatar
If there is a "droop" in the vent line, you will have an air lock and it will not allow water to be added. If you can, blow through the vent line to see if it is clear or you hear any gurgling. Mine had air locks in both fill and vent lines. Had to remove the belly cover to fix both lines.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 01-27-2016, 09:48 PM   #12
TURBS's Avatar
Shouldn't be a check valve in the fw fill or vent.
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-27-2016, 09:48 PM   #13
It seems that I will need to remove the underbelly also to figure this one out. I only boondock a few times a year so it's not a major issue but I just want it available when I need it. Thanks for all of yalls replies. Much appreciated.
Old 01-27-2016, 10:05 PM   #14
TURBS's Avatar
Please let us know what you find!
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-27-2016, 10:10 PM   #15
I will probably not tackle it until spring but I certainly will let y'all know the conclusion. Thanks again.
Old 01-28-2016, 01:28 PM   #16
You have water in your vent line. Just blow the vent line back into the tank.
3886john is offline   Reply With Quote
Old 01-30-2016, 02:02 PM   #17
Pebbles's Avatar
I have a brand new FR Stealth 5th wheel. Been boon docking several times and no problem filling fresh water.Hooked up to city water once and since then fresh tank won't fill. Air trapped in line maybe? How to resolve please?
Pebbles & BamBam
Pebbles is offline   Reply With Quote
fresh water, tank, water, water tank
