Old 01-27-2016, 11:41 AM   #1
Fresh water tank not filling
I have Sabre 291bhts and the fresh water tank is not accepting the anti-freeze. I have owned this unit for several years and winterized every year with the same process of adding the pink stuff through the fresh water fill but for some reason this year it seems that all the anti-freeze is staying trapped in the full line and not making it to the fresh water tank. Any suggestions on what may be causing this?
kodiak75 is offline   Reply With Quote
Old 01-27-2016, 11:45 AM   #2
TURBS's Avatar
Not sure why you'd want to even use the fw tank?
Install a winterizing kit .
You'll use way less antifreeze and faster.
I installed my winterizing kit on my Sabre in less then 30 minutes.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-27-2016, 11:48 AM   #3
TURBS's Avatar
http://www.rvautoparts.com/Camco-Pum...2OGxoChMfw_wcB
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-27-2016, 07:16 PM   #4
Thanks for the reply. I have purchased one and will install. My concern is that when its time to fill the fresh water tank with water for camping, the tank won't fill. Any suggestions on why the tank won't fill?
Old 01-27-2016, 07:20 PM   #5
Ford Idaho's Avatar
Have you tried to put water in it?
How many gallons is it?
Gravity feed or pressure fed?
How many gallons or antifreeze did you use?
Did you run the pump and put some A/F in the water heater?
Old 01-27-2016, 07:32 PM   #6
The tank is a 47 gallon gravity fill. I filled the tank in August for some boondocking at the Bristol race and it filled and worked fine. I drained water heater and bypassed it during winterizing process in October but the tank would not fill, even after adding about 3-4 gallons of anti-freeze.
Old 01-27-2016, 07:42 PM   #7
TURBS's Avatar
You sure it isn't full ?
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-27-2016, 07:54 PM   #8
Positive! I opened the fresh water drain on the bottom and hardly any fluid drained from tank. I also inserted clear tubing down the fill line and when I removed the clear tubing from the fill line, it had anti- freeze on the clear tubing. Maybe I have a kink in the fill line but with the covered underbelly it's hard to see if that is the case. The camper is in storage about 30 minutes away. I may just wait until spring to remove underbelly and investigate further.
Old 01-27-2016, 08:07 PM   #9
TURBS's Avatar
Did you try to stick a wire up the fw drain tube?
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-27-2016, 08:20 PM   #10
I have not. Is there a check valve that would keep the fw tank from filling? I did apply air pressure to the screen above the fill access to be sure there wasn't a blockage there.
fresh water, tank, water, water tank
