Old 02-20-2019, 09:44 PM   #1
Fresh water tank not taking water
I'm having a problem with my 2018 Rockwood 8298WS Signature Ultralight 5th wheel fresh water tank. When I try to fill the tank with the hose, water leaks from the underbelly through the bottom protective cover. Any thoughts on what it could be?
bushwacker is offline   Reply With Quote
Old 02-20-2019, 09:55 PM   #2
filler tube leaking at joint from tank? still under warranty?
Kimber45 is offline   Reply With Quote
Old 02-20-2019, 10:36 PM   #3
Yes, still under warranty but not sure where it's leaking. We're currently on the road and need to fill the fresh water tank.
Old 02-20-2019, 10:47 PM   #4
cavie's Avatar
There is an overflow/vent line. Perhaps your tank is full? You should be able to see a drain line and the vent line. The drainline will have a valve on it. Perhaps it is open and that is why your are seeing water. Take a closer look.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 02-20-2019, 11:00 PM   #5
Thanks cable for the advice but I have checked the drain and it is indeed closed. Pretty sure the problem in with the fill tube and tank connection. Was hoping there was a quick fix.
Old 02-21-2019, 08:53 AM   #6
rracer5's Avatar
Probably just a loose or missing hose clamp. Detach part of the underbelly cover from just below your fill tube and peek in there with a flashlight. You should be able to see the filler tube going to the tank and maybe reach in to tighten the clamp.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-21-2019, 09:21 AM   #7
Thanks, I'll give that a try.
Sent from my VS995 using Forest River Forums mobile app
Old 02-21-2019, 01:41 PM   #8
DustyRoads's Avatar
Your tank isn't in bypass valve setting is it. I know stupid question.
2017 Forest River Surveyor 251rks
2016 Chevy 2500HD
DustyRoads is offline   Reply With Quote
Old 02-21-2019, 03:19 PM   #9
No, it is not.
Old 02-21-2019, 03:47 PM   #10
Thurman's Avatar
"When I try to fill the tank with the hose, water leaks from the underbelly through the bottom protective cover." I would like to clarify something: Your statement says to me that when you try to fill the tank water leaks from the underbelly. 1) Does the water start to leak soon after you start to fill the tank or 2) Does the water start to leak after the water has been running into the fresh water tank for a few minutes?. IF 1) then I would suggest you look at the fill hose not being attached to the tank properly. Unfortunately you may have to cut an access hole in the underbelly cover to be able to see the connection where the fill hose attaches to the tank. I would recommend cutting a three-sided hole at an area where you think the hose attaches to the tank. When cutting a hole such as this imagine this hole much like a square. Cut the back line and the two side lines leaving the front line as a hinge, this make taping it back up really easy. Now, IF 2) then the tank may be getting full and the overflow hose may not be attached properly, which again leads to an access point (hole) to see where the overflow line attaches to the tank. I know that the indicator lights showing how full the tank is are often misleading but by chance have you looked to see how much water the indicator is showing? Your tank may have more water in it than you think. Another issue: When the water starts to leak from the underbelly go look at the fresh water tank indicator and see how much water it indicates. Then wait until the leaking stops and read the indicator again. The leak may just be an over fill line not properly attached and the tank actually gets full just before the leaking begins. Being as this is a 2018 model 5-er I would certainly call the selling dealer, tell him your problem and location. They just might be able to find a dealer in your area who would take a look at this under warranty.
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
fresh water, tank, water, water tank
