Old 10-25-2015, 08:23 PM   #1
Sagecoachdriver's Avatar
Fresh water tank not totally draining
I have added a hatch to visually see my tank level with markings. I drained it to add fresh water for our trip tomorrow. For some unknown reason, the water level dropped to only my first marking which is 3.5 gallons. 3 days ago when I drained the tank it was empty visually. Could the drain be blocked by a piece plastic hole cutout for the filler, air vent or drain fittings?
I understand that all the water can't be drained out, but how do you folks that winterize deal with residual water left in the FW tank?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
Sagecoachdriver is offline   Reply With Quote
Old 10-26-2015, 06:29 PM   #2
Is the hatch on the drain side of the tank or the opposite side? If it's on the opposite side, the vehicle could be slightly tilted away from the drain side.
If it's not that, it could be a piece of debris partially blocking the drain.
Gotta go campin!
Old 10-26-2015, 07:33 PM   #3
Blackhat6mike's Avatar
My freshwater tank was full of plastic giblets that kept stopping up different faucets and valves and the freshwater pickup bung was 2' off the bottom of the tank. I couldn't lift water when the gauges said 1/3 full, just sucked air. I blocked the pickup bung on the side, installed a "T" on the low point drain and rerouted the freshwater pickup off the T. I can now drain it dry either way, but still get pieces of plastic trash now and then.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 11-03-2015, 12:14 AM   #4
MNtraveler's Avatar
Stick a pipe cleaner or piece of clean wire up through the drain and see if you can dislodge anything?
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
drain, fresh water, tank, water, water tank
