Old 08-19-2011, 04:48 PM   #1
rbarrieau's Avatar
fresh water tank overflow?
just filled my fresh water tank for a trial dry camping weekend in the backyard. Question-- when the tank is full does it overflow out of a hose on bottom of camper? And what would keep creatures from entering in to the tank thru this hose?
rbarrieau is offline   Reply With Quote
Old 08-19-2011, 05:14 PM   #2
Yes. the drain hose is typically 1/2 inch PVC so i don't see this as an issue. Mine does/did have a valve at the bottom that needed to be opened the first time. Otherwise I cannot fill my tank.
Old 08-19-2011, 08:29 PM   #3
prof_fate's Avatar
There is a vent hose that doubles as the overflow...it's supposed to run from the tank up to the fill area to a small round screen there. For whatever reason many FR trailers leave this hose off - so there is nothing to prevent critter infestation, road salt or crap from kicking up in there and a full tank will 'pee' on the road as you drive and the water sloshes around.
It's on the list of things I'll be fixing after the season. I can run a hose myself fairly easily, just need to 'drill' a hole in the foam used to fill the hole that all the other hoses run through in my TT under the bath vanity. YMMV
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 08-20-2011, 09:22 AM   #4
rbarrieau's Avatar
H20
thank you .. One more issue is the switch for the hot water should have an indicator light on it ..it is easy to forget it is on when packing up to leave a site. I may paint the top of the rocker swith withbright red paint.
