Old 07-09-2012, 01:37 PM   #1
Fresh water tank removal.
I have a 2003 Forest River motor home model 325. When the water tank is filled above 2/3s it leaks. I have looked for the leak and am unable to see any leaks. I checked the pipes in and out and no leaks. The tank is located above the basement compartment and under the bedroom closet. Has anyone ever removed one? If so what is the best way to remove it so I can replace or repair it.
THELMALOUIE is offline   Reply With Quote
Old 07-10-2012, 08:34 PM   #2
i don't know anything about removing the tank, but like many others, when I get my water tank close to full, it will drain out the overflow tube. It then creates a suction and will continue to drain and partially collapse the tank. There are a few threads with suggested fixes. I put a valve on my overflow tube which has done the trick for me.
I hope your tank drip isn't serious, good luck.
akcampr is offline   Reply With Quote
