Old 08-16-2018, 08:39 PM   #1
forestdweller's Avatar
Fresh water tank sensor doesnt work.
New 2019 wild wood. Filled up water tank for first time. Reads empty. Only two things i can think of are 1) theres alot of dust like stuff in the water here as its from a well, could it throw off the sensor? or 2) the hose going into the fresh water tank really blasted in there, the pressure was much higher than I thought, did it damage the sensor? Someone else said probably it didnt.
forestdweller is offline   Reply With Quote
Old 08-16-2018, 09:08 PM   #2
Duckogram's Avatar
Did you charge your battery yet?
ILB
Old 08-16-2018, 09:09 PM   #3
I charged it for about 20 minutes on the generator. Probably wasnt enough time yet. The battery meter went up to 1/3. Ill try more tomorrow.
Old 08-16-2018, 09:13 PM   #4
Duckogram's Avatar
When it comes to your battery, I suggest you stop looking at those little red lights and use a volt/multi meter. There are tons of threads in the electrical section on how to care for your battery and what happens if you do not.
ILB
Old 08-17-2018, 04:12 PM   #5
You will find out as you go that those sensors are worthless.
Walholler is offline   Reply With Quote
Old 08-17-2018, 08:00 PM   #6
bedubya's Avatar
^ x2
'17 Toyota Tacoma 4x4
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
bedubya is offline   Reply With Quote
Old 08-18-2018, 09:11 AM   #7
Only sensor that even begins to try to work on my Crusader is the water tank. Black tank goes from empty to full with nothing in between, and the greys are always empty, (is that a good thing?). Even if they are giving you a reading, don't trust them.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 08-19-2018, 10:39 AM   #8
Water tank sensor not operating
There must be replacement or substitute products available after-market that reliably measure tank volumes.
Our grey water sensor on '17 FR 2401 Forrester stopped working on day 366 of warranty. Always empty.LOL.
Phil & Joanne
South Jersey
zj178 is offline   Reply With Quote
Old 08-19-2018, 10:47 AM   #9
Flybob's Avatar
A deeply depleted battery will take 6-8 hrs to charge back to almost full.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-21-2018, 09:24 PM   #10
Tank Sensors
Go under the trailer with a small incandescent test light and touch the sensor pins while someone inside the trailer pushes the button and watches the lights. If they work, the tank ground pin is not grounded. Those Scotch-Lok connections are not reliable. That was the problem with mine and all the sensors work now on all tanks.
GlennW is offline   Reply With Quote
fresh water, tank, water, water tank
