Old 03-04-2018, 02:54 PM   #1
Question Fresh Water Tank Vent?
Our 2008 Georgetown XL has the annoying habit of draining the fresh water tank out through the vent hose while driving.
Short of putting a plug in the end of the hose, hopefully remembering to remove said plug when not hooked up to city water, has anyone found a simple easy solution? This has been one factor preventing us from much dry camping.
RandL is offline   Reply With Quote
Old 03-04-2018, 02:59 PM   #2
NMWildcat's Avatar
Lots of threads on this. All seem to boil down to two options: 1) reroute your vent tube above the water level and include some loops in the hose. 2) install a fitting and a valve on the end of the vent hose.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 03-04-2018, 03:18 PM   #3
PPST Wannabe
kenandterry's Avatar
I installed one of these on the vent hose which is easily seen and accessible in my fresh tank and water pump compartment.
https://www.homedepot.com/p/LEGEND-V...-600/203581050
I fill up my fresh water tank until it starts to overflow out. Give it a minute or two to settle, and if itís still running out, shut off the tap.
By the time we get to a point for dry camping, itís part of my set up routine to open the valve and we have access to the maximum capacity of the fresh water tank.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
fresh water, tank, vent, water, water tank
