Old 05-18-2016, 08:16 AM   #11
Kaadk's Avatar
Originally Posted by Wolverine 1945 View Post
BE VERY CARFULL with that filler,,,
Several years ago we were using one of those,,, the wife went to remove it from the filler tube,,, and the clear plastic hose fell into the FW tank,,, as far as I know it is still in that FW tank !!!
But I do use the yellow valve on the end of an inline filter !!!
Yep, I've had it separate on me before too, but thankfully it didn't go in the tank. I've learned to first shut off the valve, then lift slightly so you pull it straight out. Trying to pull it out on an angle seems to have been the issue.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 05-18-2016, 09:33 AM   #12
Tom48's Avatar
Originally Posted by Pebbles View Post
OK, so we can't put water in the fresh water tank via the gravity fill. It will take so much then burps out as if full. Took it to the dealer once and they supposedly fixed a kinked hose, but it's doing it again. Of course we will take it back so they can do the job right this time, but going camping this weekend and need to get water into the tank. Anyone know of a hack to make this work? I looked underneath, if there is a kink in the line it's not anywhere that's visible. Must be behind a wall or something...
Please share Make and Model of your unit.
Tom48 is offline   Reply With Quote
Old 05-18-2016, 09:38 AM   #13
Is this a brand new trailer? When we first got ours the tank was installed with the tank fill hole higher than the exterior fill hole. Palomino sent me new piping so I could orient the tank the correct way on its side which made the tank lower than the outside fill hole.
keith_h is offline   Reply With Quote
Old 05-18-2016, 10:00 AM   #14
Briorick's Avatar
We encountered this same problem when we first started the initial fill of our new TT getting it ready for a weekend out. Water kept back flushing out like it was indicating the tank was full. Finally figured out it was not the case when I looked a t the FW tank level underneath. Although I was able to get quite a bit ( approx. 1/2 full ) water into the tank ,and yes, quite a bit on the ground while filling, but it worked well enough for the first time out.
After our outing, I located the hose inside the TT that fed into the FW tank and seen there were no kinks, obstacles, nothing to keep the water from flowing in. So I read ( on this site ) how another had used a 3 foot smaller hose, and inserted it down into the FW opening and was able to fill up their FW tank easily thereafter. What did I have to lose. IT WORKED PERFECTLY!
I also purchased a water flow meter and attached it to the end of the smaller hose as to indicate the water volume going in. Have used it 3 times now and can fill up the FW tank with no problems, thanks to that smaller diameter hose and a mod suggestion from another on this forum. The meter is a P3 International Save A Drop Water Meter - P0550 purchased off eBay.
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 05-18-2016, 10:09 AM   #15
jeff64's Avatar
That smaller 3' hoses stuffed in the filler neck makes sense to let the air out. Good to know about the camco filler coming apart
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-18-2016, 11:09 PM   #16
We used to have this problem in both our Rockwood and now our Wildwood (to a lesser extent). I've solved the problem by buying about a 15 foot 1/2 inch diameter water hose and cutting off the nozzle end. I then snake the hose down to the bottom of the water tank and fill it slowly. Filling from the bottom up allows the air to escape easily and has solved the problem we had of severe and frequent "burping".
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
Old 05-20-2016, 10:55 AM   #17
Unhappy
We just found out that the filler hose on our new Wildwood was going up.
DH opened panel under fridge and pushed down so it was flatter. The tank filled but now it won't drain!!
We also found out, after finding the screened opening filled with caulk that there isn't any breather tube going to the tank from the filler connection. Wa11y was good enough to tell me that the breather hose on this unit comes out of the top of the tank and drops down beside it.
Something new all the time.
2016 Wildwood 26TBSS
2012 F150 Screw XLT
4 legger Halley
TreeLady is offline   Reply With Quote
Old 05-20-2016, 11:14 AM   #18
KyDan's Avatar
To the OP who's trying to fill a fresh tank-
Have you tried this- You need a piece of garden hose that's at least 2 feet long with the male end cut off. Shove the hose into the fill port as far as
you can. Attach garden/drinking water hose and turn on faucet.
This can often "shoot" the water past the low point and into your tank.
I use cut off washing machine hoses because we never use the rubber hose that come with a new washer. We buy stainless braided hoses and use the rubber one's as bucket fillers in the garden and tank fillers in the RV!
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
fresh water, water
