Old 07-09-2016, 09:30 PM   #1
duradiesel's Avatar
Freshwater tank
I had to drop the cove under the 5th wheel for a oil leak in the lines for the rear slides. I noticed the bottom of the freshwater tank is bowed down about 3 inches . Is the tank made like that or is it from the weight of the water? I was thinking of fitting a piece of plywood under it to keep it flat . there is probably about 5 to 10 gallons of water in there .
2006 GMC Duramax Extcab LB
2012 Wildcat Sterling 32RL
duradiesel is offline   Reply With Quote
Old 07-11-2016, 01:25 PM   #2
Head Rambler
That's a pretty common complaint around here. The tank is manufactured flat on all sides, but it's pretty thin and therefore bows under the weight of the water. Since it's only supported on the sides the bottom bows pretty significantly. Supporting it better won't hurt anything and may save it from falling out, which is another complaint.
Gotta go campin!
Old 07-11-2016, 04:09 PM   #3
duradiesel's Avatar
Thanks for the reply. I just finished putting 2 pieces of 1/2 plywood under the tank. I had a lot of water come out of the drain which has been open for 2 weeks since our last trip. Leaving tuesday for 7 days.
tank, water, water tank
