04-02-2019, 08:20 PM
Green Horn
freshwater tank
Tank seems to drain slow,filled tank 2/3 full (test water pump and check for leaks) opened up low point drain (rear of coach) seems to drain slow is this normal?
04-02-2019, 08:42 PM
My drain hose was kinked from the factory.
04-02-2019, 08:45 PM
Jayhawker
We had a similar problem last summer with our fresh water tank not draining. Discovered a mud dauber had plugged it up. Took a wooden dowl rod and rubber mallet to unplug it.
04-02-2019, 08:48 PM
You need to use the fresh water tank drain to drain the tank itself. The low point drains drain the water in the water lines. When using them you need to open up a hot and cold faucet to vent the lines.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
04-02-2019, 09:06 PM
Low point drains do not drain the FW tank. There is usually a valve at the tank to drain it.
Sorry Bob, didn't see your post. You nailed it.
04-03-2019, 07:40 AM
Green Horn
ok, I'm lost, We have a 5th wheel silverback, the only valve I see i have is "city" and "gravity" I used Gravity to fill the tank but now i want to drain the tank, (i'm a new camper and this is our first rig) I am also still hooked up to my house (City) water do i need to disconnect then will it drain?
We are "camping in our yard to learn how to work everything
Thank you
04-03-2019, 07:42 AM
Green Horn
oh and the underbelly (frame) is enclosed
04-03-2019, 07:44 AM
Green Horn
ok i did notice at the friont of the coach i have another set of low point drains these have "caps" on them would these be the ones to drain the tank?
04-03-2019, 07:45 AM
Thank you
I can't see under your unit from here but my fresh water tank has a pipe/tube coming straight out the bottom of it - centered side to side of the tank but closer to the outside end of the tank. That pipe/tube on mine has a cap on the bottom end - no valve. I have to take a knee and screw off the cap (and retain the rubber washer). I usually open the fresh water gravity fill cap to allow air in faster than just the vent tube.
04-03-2019, 07:46 AM
Can you find your fresh water tank? I'm guessing it's right below your gravity fill.
04-03-2019, 07:58 AM
Mine is below the fill ... a tube with a valve ... back of 5ver ... no where near city hook up or flushes they are in side storage pass thru
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
04-03-2019, 08:42 AM
My fresh water drain is right below the tank on the underbelly. Looks like this
04-03-2019, 08:52 AM
Green Horn
Originally Posted by happyttowner
My fresh water drain is right below the tank on the underbelly. Looks like this Attachment 200616
Yep that's what mine looks like, I ended up putting a metal rode up thru the opening and found it was blocked, now we are draining..... now do i trust to fill it up the whole way to see if the overflow vent is working...lol
Thank you to everyone that help me....
04-03-2019, 08:54 AM
Tell us what kind of unit you have.... motor home, 5th wheel, bumper pull? And what kind is it?
04-03-2019, 09:39 AM
Jayhawker
[QUOTE=kevin211;2062403]Yep that's what mine looks like, I ended up putting a metal rode up thru the opening and found it was blocked, now we are draining..... now do i trust to fill it up the whole way to see if the overflow vent is working...lol
You should be good to fill now. When we have been filling our fresh water tank at the gravity fill sometimes it won't take water in very fast, and will spray back even though it is far from full. The problem is the screened vent is clogged. I remove the clear tube from the Camco water tank filler and blow on the screened vent to clear it. Works every time. Hope this helps!
04-03-2019, 09:52 AM
I know you resolved your fresh tank drain issue but I don't believe anyone addressed this question.
These are your low point drains for the hot & cold plumbing.
You mentioned low point drain when describing your fresh tank drain in your original post but I'm betting you were referring to your tank drain then.
These often colored blue/red lines (not always) with the caps are your actual low point drains as they are called in the R/V industry.
I put valves on mine to make draining easier.
04-03-2019, 10:02 AM
I find that my tank drains faster when I open a cold faucet.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
Thank you
Low point drains will not drain fresh water tank. There should be a pipe comming thru the underbelly just below the fresh water tank. My experience is most come from factory with a scew off cap on the end... Some replace this cap with a valve for easier use. Remove this cap to drain Fresh water tank.
Oops.... already solved I guess
04-03-2019, 07:48 PM
Green Horn
Purchased a 2015 Silverback 29IK 5th wheel, looks to be a demo unit,all the labels are still on everything.
04-04-2019, 10:21 AM
Denver To Yuma In 90 Days
Marty
Opening a faucet should have no effect on how the fresh water tank drains.
Unless maybe if the check valve has gone bad in the water pump.
It will, however, allow the plumbing to drain faster.
