Old 12-06-2018, 10:44 AM   #21
BandJCarm's Avatar
I have the Pocket Version of this:
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 12-06-2018, 10:45 AM   #22
pokey's Avatar
Frozen water hose
Ah my water is running now. I'll never say never but try to never let it happen again. And.......fill my fresh water tank. Thanks all for your replies.
Pokey
Permanent RV'er
2006 Cardinal 29LE
Why do today what you can put off until tomorrow.
Retirement life........
pokey is offline   Reply With Quote
Old 12-06-2018, 10:50 AM   #23
pokey's Avatar
That's pretty cool, I'm going to look it up. Thanks!
Pokey
Permanent RV'er
2006 Cardinal 29LE
Old 12-06-2018, 11:00 AM   #24
pokey's Avatar
$22.98 US not bad. I may order one for myself. How do you forecast with it in your pocket or take it out when you arrive?
Pokey
Permanent RV'er
2006 Cardinal 29LE
Old 12-06-2018, 11:40 AM   #25
Running the water in a trickle or a slow stream can be risky. If the water pressure is low in the park or the park water lines freeze, you can still end up with frozen pipes.
All good solutions above....
Also, if you get up in the middle of the night, run hot and cold water through all your faucets. You'll clear out the ice crystals forming in the lines.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 12-06-2018, 11:47 AM   #26
pokey's Avatar
I should receive the heated water hose in a couple of days. After that there should be no need to trickle or stream.
Pokey
Permanent RV'er
2006 Cardinal 29LE
Old 12-06-2018, 12:06 PM   #27
Flybob's Avatar
What is keeping the pedestal supply line and shutoff from freezing?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-06-2018, 12:15 PM   #28
pokey's Avatar
Pedestal supply as in the electric pedestal or? Which shut off do you mean? Thanks
Pokey
Permanent RV'er
2006 Cardinal 29LE
Old 12-06-2018, 12:29 PM   #29
pokey's Avatar
If you mean the pedestal electrical, supply line and shut off nothing. I see no reason to.
Pokey
Permanent RV'er
2006 Cardinal 29LE
Old 12-06-2018, 12:31 PM   #30
pokey's Avatar
To protect it that is. They're all above ground, homes etc. My line runs along the grass.
Pokey
Permanent RV'er
2006 Cardinal 29LE
fresh water, water
