Old 02-19-2018, 11:37 PM   #1
Frozen tank valve handles
Need a easy fix other than wait until in warms up (32 now going too 10 over night)water hose not connected have been emptying tanks at night
Thanks in advance
DonMar is offline   Reply With Quote
Old 02-19-2018, 11:44 PM   #2
Nurek's Avatar
Hair dryer?
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
Nurek is offline   Reply With Quote
Old 02-20-2018, 09:39 AM   #3
Thanks some we over think things ��
Clermont, Florida
2015 Surveyor 265RLDS
2011 Trundra TRD
2017 Ford F250 4/4
Old 02-20-2018, 10:16 AM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Yes, hairdryer works and is relatively safe but it can take hours sometimes.
Take your time, don't yank on the handle.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 02-20-2018, 10:57 AM   #5
If you expect this to be a problem in your future with lots of camping in freezing weather you might consider adding the heat pads to both 1-1/2 and 3" drain pipes and valves.
This company makes some heaters for drain pipes, elbows, and valves, that run a little hotter and are designed to just be switched on shortly before draining.
RV and Marine - Heaters & Warmers - Shop
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 02-20-2018, 02:14 PM   #6
People overlook a common item. IPA -Isopropyl alcohol Just add to tank.
Often folks not in the know use such in the winter to add to the fuel tanks. Commercially sold as Heat.
The IPA will free the handle and is available at the dollar store for around $.75 per pint.
TonyShope is offline   Reply With Quote
Old 02-20-2018, 02:36 PM   #7
Denver, CO
garbonz's Avatar
Gonna take a lot of IPA to do that to a tank with liquid in it, and no reason not to use RV antifreeze which is propylene glycol, same effect, freezing point depression.
2017 Fuse 23T
Old 02-20-2018, 02:37 PM   #8
MacDR's Avatar
Never thought of using Heat to free up a Frozen Tank Valve Valve.. but next time you empty your tank. Poor a cup or 2 of RV antifreeze in after you close the valve..
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Day's Camped 2018 "32"
You can find us: CrockeryCreek RV Park, MI 9/29 - 10/1
MacDR is offline   Reply With Quote
Old 02-20-2018, 02:46 PM   #9
Dahagen
When it is going to be below freezing I put a 110 volt trouble light in the compartment with the valves and leave the light on. Assuming you are not dry camping. And make sure the bulb is incandescent, NOT LED.
dahagen is offline   Reply With Quote
Old 02-20-2018, 03:32 PM   #10
5 Gallons would unfreeze a 25 Gallon tank in less that 5 hours @ 10 degrees F
I live in the cold and have helped many a neighbor in the CG fix the draining issue.
RV antifreeze Gels which is undesirable.
tank, valve
