Old 12-20-2015, 12:54 PM   #11
bend302's Avatar
Are you sure the tank valve is open?
Another option is to get a Flush King with a gate valve and try to force the clog out from the bottom with a garden hose. From what you have described I would be surprised to find it still frozen.
Bill
bend302 is offline   Reply With Quote
Old 12-20-2015, 01:13 PM   #12
rsdata's Avatar
I vote for the Flush King
Amazon.com: Valterra F02-4350 Reverse RV Flush Valve: Automotive
or the Camco unit
http://www.amazon.com/Camco-39062-Fl...rds=flush+king
to help out. By back filling a little, then draining and back filing over again you should be able to wash the gunk out.
Here is a video on how to use it.
https://youtu.be/oi8HUknP46Y
Maybe the warmer weather forecast this coming week for the eastern half of the US will help if you are in that area.
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 12-20-2015, 01:28 PM   #13
How about turning off the water to the toilet, then flushing it with very hot water poured down the toilet? Sounds like you need to thaw out a block of poo.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 12-20-2015, 02:08 PM   #14
Originally Posted by Hawk53 View Post
Pretty sure it is the tank cuz it partially froze and there is plenty of enzyme liquid in the tank. Also when I flushed last time the level came up in the pot!!! So there is no room for more liquid right now!! It is a real problem..... Also I had a 500 watt halogen light under it for four hours to heat it up..... Really confused as to why it will not drain... If I unhook the hose to snake the pipe I will have a major mess in the middle of the RV park if it lets go.....
Hawk53,STOP rite Now ,Go buy a Plastic Kiddee Pool and place under your Dump valve,now you can (Snake/Work) on your Valves without (Being Run Out of the C/G)! Youroo!!
Old 12-20-2015, 02:09 PM   #15
TURBS's Avatar
Did he not say the tank is full of water?
Old 12-20-2015, 02:23 PM   #16
Lots of boiling water
Harkerr is offline   Reply With Quote
Old 12-20-2015, 02:24 PM   #17
Pickin' & Campin'
He did.
He also said he shut off the water and ran a snake down through the tolit and was 'certain' he went through the valve. If he did in fact get a snake out through the valve that would mean the block is somewhere after that.
I don't know the specifics on how much pipe may be between the valve and where he hooks the sewer hose on so it's tough to keep guessing as to where the problem lies without knowing more details.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 12-20-2015, 02:41 PM   #18
Frozen black tank
Obtain a elbow with a flush hose hookup, and attach it to the drain, then reattach the hose. Run a high pressure steam in from the bottom to thaw the valve. Although you may have the valve rod pulled the actual gate may still be slid across the opening. If you were pulling on the rod while the gate was stuck to the frozen contents it could have pulled free. See if the valve Rod seems loose or if it is actually moving the gate.
hankpac is offline   Reply With Quote
Old 12-20-2015, 03:29 PM   #19
retired06's Avatar
I wonder if that calcium products used to melt ice dams on roofs would help or hinder.
Don't worry about the mule, just load the Wagon!
2015 Grey Wolf 19RR (Wagon )
2014 F150 XLT ECO Boost max tow (mule)
retired06 is offline   Reply With Quote
Old 12-20-2015, 04:37 PM   #20
A blast plunger will likely not work as the black tank is open vented to the roof of the camper.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
black, black tank, tank
