Old 02-29-2016, 01:22 PM   #1
Valhalla's Avatar
Question Full Hook-up sites
My DW says this is a crazy question but I gotta ask the experts...
When you are staying at a full hook-up site, do you open the valves to both the gray and black tanks, just open one valve of either tank, or keep both closed until you leave?
2014 Coachmen Viking 16FB
2005 Chevy Trailblazer EXT 4x4
36 Nights Camped in 2015
Valhalla is offline   Reply With Quote
Old 02-29-2016, 01:26 PM   #2
JustB_Rad's Avatar
Grey open all the time (until our last full day, then I close it)
Black closed ALL the time. You don't want paper and other solids getting caught in the tank. Gravity takes them out when you pull the valve and there is liquid to go with it.
Empty black first, then grey.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 02-29-2016, 01:27 PM   #3
Ejs4029's Avatar
I leave both valves to the gray and black tanks closed....When the Black tank is close to getting full I dump it and then dump the gray to clean out the hose....
2015 Dodge Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Ejs4029 is offline   Reply With Quote
Old 02-29-2016, 01:29 PM   #4
RollingDownTheHighway's Avatar
I leave the black closed, and the grey open. The only time I close the grey is when I'm getting ready to dump the black. I use the grey to "wash out" the hose. On the day of checkout, I close both and run the black tank flush then drain them all. I run the flush a few times on the black tank
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 02-29-2016, 01:39 PM   #5
Fulltime family RVer
Black closed until actually dumping. Gray always open. I run a LOT of water through the black tank flush and use that to clean out my hoses.
Old 02-29-2016, 01:42 PM   #6
Mr. Dan's Avatar
My process is to keep gray and black closed until we need to open one/both.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 02-29-2016, 01:47 PM   #7
Bluepill's Avatar
Same here. Protects from a potential grey water mess if the hose becomes disconnected. Think of someone cutting across your site in the dark and stumbling over the hose.
2008 Itasca Meridian 37H
Old 02-29-2016, 01:52 PM   #8
Valhalla's Avatar
Thanks for the quick replies!!
Thank you for all your quick replies. I will continue my process of keeping both tanks closed until they need to be dumped.
