Old 04-29-2013, 10:23 AM   #1
Full pressure when using the tank flush??
I know that you should use a pressure regulator for city water when hooking up, but do you also use a regulator when you are flushing your black tank?
Thanks,
Craig
Sandblaster is offline   Reply With Quote
Old 04-29-2013, 10:35 AM   #2
I was wondering that too... I dumped my black water tank after a trip this past week and my sensers still show it is 3/4 full. Have you or any body experienced this before?
chevy2500 is offline   Reply With Quote
Old 04-29-2013, 10:38 AM   #3
fonzie's Avatar
I use full pressure and a hose dedicated for that.
Fonzie
Old 04-29-2013, 10:38 AM   #4
Fulltime family RVer
Just this year, I took my black tank flush off of my water regulator (to save me a step hooking up). I don't foresee it being a problem.
As for the previous poster... yes, it's common that toilet paper gets on the sensors and shows a false reading. My 1/2 bath doesn't have a black tank flush yet- I've had to fill it with fresh water and then re-dump to get the TP off of the sensor.
There are replacement sensors (Horst Miracle Probes) that are a bit better. The factory sensors are pretty well know to be inconsistent.
Old 04-29-2013, 10:43 AM   #5
mjones12's Avatar
Thanks,
Craig
I had that same question and was told by a very reliable source on this forum that because the tank flusher empties into a large area (the tank) it is not subject to the pressure issues that our regular plumbing systems are, so no regulator is needed. It's a good question because you want as much water pressure as possible to blast the inside of that black tank.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 04-29-2013, 03:14 PM   #6
Thumbs up
Thanks for the information. I probably need to do that.
Old 04-29-2013, 03:15 PM   #7
Herk7769's Avatar
Me too.
HAM CALLSIGN - KC3FFW
Old 04-30-2013, 07:54 PM   #8
Might need to clean your tank sensors remove them and clean the crud off of them and reinstall
amdavis20 is offline   Reply With Quote
Old 04-30-2013, 08:16 PM   #9
VinceU's Avatar
Mine also came with the tank flusher fitted on the other side of the black tank. It does a good job of rinsing the tank clean however its too far and not concentrated enough to keep the probes clean. Traveling with TP on the probes should knock it off but doesn't. The problem is more like debris film coating between the probes which is just conductive enough to make circuits to the return side of the probes. I use a high velocity probe nozzle I fabricated from plastic pipe. You can also buy them commercially. Its a pain to bring a clean dry hose through a window but you'll have clean tank and probes using both methods.Once a month is plenty. I'd be cautious about removing those probes too often. You'll soon have enlarged holes and you'll be SOL.
Old 04-30-2013, 08:31 PM   #10
DDC
DDC's Avatar
I use a dedicated hose also but I never came across the need for a pressure regulator unless they can increase the pressure.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
