Old 12-30-2018, 08:41 AM   #1
Galley tank drain....?
Iíve searched the forum and found many locations, but on my 2010 Flagstaff I see no such handle on the under carriage. Drained black and gray tanks, galley tank still indicates 1\3 full. Any idea?
ArmyAV8R is offline   Reply With Quote
Old 12-30-2018, 09:13 AM   #2
Tank indicators are notoriously incorrect.
Did you drain the galley tank port too or are you saying you haven't found it?
While mine are close together, some are not. Some are close the rear of the unit with a separate hose port.
My brothers Flagstaff galley drain was near the rear bumper.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 12-30-2018, 09:22 AM   #3
Thank you for the prompt reply. No I have not been able to locate any Galley drain Port. All I have, or at least all that I see are the gray and black handles located in proximity to each other. But I'll be looking again. The previous owners said that he thought that the galley drain just drained into the gray tank.
Old 12-30-2018, 09:34 AM   #4
heavynlori's Avatar
Rear kitchen units generally have a separate valve/outlet at the back of the unit
Sometimes the galley pull can be up in the frame close to the tires as well - on the driver side
Another option is there is no separate valve and the panel is generic and may have ďthingsĒ on it that your unit may not actually have
heavynlori is online now   Reply With Quote
Old 12-30-2018, 09:39 AM   #5
This camper is a front kitchen unit, The Galley is as far forward as can be. He the undercarriage is completely sealed invented, I'll continue to look but indeed it may just be showing a generic 1/3 full and mean nothing more.
Old 12-30-2018, 09:57 AM   #6
Oaklevel's Avatar
It is possible that you only have two pulls. One for grey water ( galley and grey on same pull ) and one for black. We do not have a Flagstaff but we have had it both ways on campers.
As far as the level indicators they are almost never accurate.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 12-30-2018, 10:25 AM   #7
Just wondering what the camper model number is? The ones that I've looked up so far all show 64 gal. grey water capacity which would be two tanks and probably two valves. Also, does your panel show two different tanks and two different readings? Just questions that came to my mind.
tonyz1 is offline   Reply With Quote
Old 12-30-2018, 12:00 PM   #8
Oaklevel's Avatar
It is hard to say our current and previous campers had two grey tanks, two indicators but one valve for the grey water. Our current trailer has 86 gal grey / 2 tanks (grey & galley) one dump valve.
Model number may help could have one or two valves.
1966 Mustang GT
1986 Mustang SVO
Old 12-30-2018, 12:29 PM   #9
The galley tank IS a grey tank. If the grey tank is now empty open the tank valve and run some water in the galley. Does it run out of the grey tank drain?
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 12-30-2018, 01:24 PM   #10
Thanks Oaklevel, didn't know they were doing the one valve now. We've had 2 campers with two grey tanks and both had two valves. Learned something new on the forum today. Hope OP has figured it out, great suggestion from CedarCreekWoody.
drain, tank
