Old 09-04-2014, 02:16 PM   #1
Galley Tank valve
Hello all, I have a 2002 Cedar Creek 30RLBS 5th wheel. Is there an easy way to access the gate valve for the galley tank? Can someone tell me about where it is? My cable has apparently broke loose from the valve I cut a small hole in the plastic belly cover where the handle is and stuck my hand up in there but the cable runs up and back toward the rear of the camper. I don't want to cut any more holes than I have to. Any help appreciated, Thanks!
twotnt is offline   Reply With Quote
Old 09-04-2014, 02:21 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Sorry to hear about the cable. I've had to modify my pull handle on my 5r. It's best to call a RV sales dealer that specializes in Cedar Creek 5-Rs.
donanddona is offline   Reply With Quote
Old 09-05-2014, 10:54 AM   #3
2007 WildCat 32QBBS
05CrewDually's Avatar
You may have to drop the cover to expose the valve. I wouldn't be cutting any holes. The cables are generally 6 feet long so it can be quite a ways from the pull handle. My galley tank valve is near the front axle tire, though i dont have a Cedar Creek. Hope it helps.
05CrewDually is offline   Reply With Quote
Old 09-05-2014, 09:52 PM   #4
05CrewDually, that is where my handle is and I assumed the tank and gate would be close to it, so I cut a small hole by the handle and stuck my hand up in there. The cable goes up and then toward the rear. I am hoping someone could give me an idea of where the tank is located and if there is an easy way to access it without doing any further cutting. Thanks
Old 09-06-2014, 11:27 AM   #5
Mr. Dan's Avatar
Drop the belly cover.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 14
tank
