Old 09-28-2011, 07:10 PM   #1
Unhappy Gas water heater problem
I need help. I purchased my new 2012 Shamrock 19 2 weeks ago, but I am having a problem with the hot water heater. I turn on the water heater switch, the gas fires right up like it is suppose to, then after about 15 minutes, it shuts down. I try to refire but nothing, it will not even try to ignite, the DSI indicator light will not even come on. Anyone ever experience this? Thanks for any help.
tlwtlw2011 is offline   Reply With Quote
Old 09-28-2011, 07:16 PM   #2
TURBS's Avatar
are you sure its not already to temp ? I assume if you have a 6 gallon heater it does not take long to heat 6 gallons .
Old 09-28-2011, 07:20 PM   #3
yes, it is a 6 gallon tank, but water is cold, or just starting to warm when it shuts off.
Old 09-28-2011, 07:29 PM   #4
TURBS's Avatar
just out of curiosity check your hw heater by pass valve it may be by passed which will give you cold and or warm water intermittently .
the by pass valve will be behind hw heater and you may have to remove a panel from the inside to access it .
Old 09-29-2011, 06:50 AM   #5
KyDan's Avatar
What he said!! Also be careful but you might go outside and open the
water heater door and then stand back with a rubber glove on
pull the pop off valve located near the top of the tank.
See if you get any water out and see if it is hot.
Caution it might be very hot!!
IF your bypass is on or partially on it could cause your problem.
(It might also mean the hot water tank is empty and you should never
turn on a water heater with an empty tank!!)
Good Luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 09-29-2011, 12:18 PM   #6
Jeep4Two's Avatar
Good Luck!
Good advice here. After our 2nd trip out I realized that my bypass valves were not right, all 3 valves were opened and I didn't get hot water.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
