Old 11-09-2013, 08:51 PM   #1
csowers's Avatar
Gassy water heater?
I have a 2012 Rockwood Roo 233s with a Suburban gas/electric water heater. On this trip we noticed the gas was not heating the water. The gas ignites, then we see a flame. We have allowed the water to heat for 15-20 minutes with only tepid results. When we enabled the electric, it heated with no problem. Any ideas what could be wrong with the gas system? Everything looks ok, and we are baffled.
csowers is offline   Reply With Quote
Old 11-10-2013, 05:53 AM   #2
Did you have a good roaring flame for the 15-20 minutes, or did you wait for 15-20 minutes and have tepid water? Maybe the flame went out or the gas thermostat is faulty. The gas and electric thermostats are separate, so a faulty gas thermostat would not prevent the electric part from working.
I assume that you confirmed that you have plenty of gas and that you have pressure at the stove and furnace. Do you have an automatic tank changeover valve that could have malfunctioned?
Old 11-10-2013, 06:51 AM   #3
DAISY BOYKIN's Avatar
Check the gas/ air-------------------
Check the gas/air mixture tube for any obstruction (bugs, spiders). It may be necessary to blow the tube to clean it out with compressed air to clear any obstruction. I even had to remove to clear it of a large dead spider. If there is an obstruction in the tube, it will cause an uneven flame.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is online now   Reply With Quote
Old 11-10-2013, 09:08 AM   #4
csowers's Avatar
Thanks for the input RamblerGuy and Daisy. In answer to your question, yes I did have a roaring flame for the entire 15-20 minutes. I didn't realize the thermostats were separate. Eureka, I think you've solved it! Makes perfect sense.
Old 11-10-2013, 09:19 AM   #5
There is also a reset for the electric and the gas.
