Old 06-29-2016, 10:31 AM   #1
BandJCarm's Avatar
Geo Method
OK, so we read about the GEO method and bought it. We decided to try it from the git-go on new trailer. Calgon is cheap and Walmart carries it. Got LA Cleaner off of Amazon. That and bleach and pine sol.
I don't now if it works........I assume it does............too new to know.
BUT
STINKS TO HIGH HEAVEN! Nothing in that mixture cuts the bad smell of the black tank. It permeates the entire basement and all around the camper and inside the bathroom. And we used a ton of that mixture every time we dumped.
SO........sorry, but although I buy the Calgon benefit, I'll be using that mixture but adding liquid chemicals that hopefully cut the smell!
Comments welcome.
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 06-29-2016, 10:34 AM   #2
JustB_Rad's Avatar
I just switched after a year in a new unit. I'm not sure it works either, however, I haven't gotten the smell you describe. I'm using Calgon and a cheap bottle of Dawn.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 06-29-2016, 10:37 AM   #3
(Dry Huunday)
DreiHunde's Avatar
Hmmm ...I just use 1 cup each of Calgon and Laundry Detergent, no smell and so far (2 years) it seems to work ok.
And we use the toilet for everything toilets were intended for!
Strange
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is online now   Reply With Quote
Old 06-29-2016, 10:46 AM   #4
BandJCarm's Avatar
Hmmmmmmmm.
Odd. But this was same for about 5 tank dumpings over a 10 day camping period.
Residual smell still lingers, in driveway.
FROG AR-0019-242
Old 06-29-2016, 10:52 AM   #5
JustB_Rad's Avatar
Originally Posted by BandJCarm View Post
Hmmmmmmmm.
Is your vent pipe clear?
Old 06-29-2016, 10:53 AM   #6
(Dry Huunday)
DreiHunde's Avatar
Do you leave any water in the tank? After I dump I add the mixture with 2 or 3 gals of water to the tank.
Beau & Sue
FurKid Express
Old 06-29-2016, 10:56 AM   #7
BamaBob's Avatar
Try this:
The first thing to remember is the holding tanks are just that, "Holding Tanks" and not a Septic System!
DO's
•Use plenty of water when you flush.
•Let the tanks fill to at least 3/4's full before dumping.
•Dump the Black Tank 1st & Gray Tank 2nd.
Don'ts
•Don't leave the black tank dump valves open or you just might end up with the dreaded pyramid ‘o poo J.
•Don't dump anything other than water down the kitchen sink. Why? The Gray Tank does not have a power rinser and the outlet pipe is only about 1-1/4" compared to the 3" black tank drain line. This allows food particles to remain in the tank.
•Restrict the use of chlorine bleach. It's bad for the seals and not really good for a septic system (the place you are dumping YOUR holding tanks.
•Don't mix rinse tank hoses with fresh water hoses. (Ewwwww!...but I have seen this done on multiple occasions at campgrounds!)
Dump/Rinse Procedure
1. Put on a set of gloves – I went to farm supply and got a really nice pair of chemical gloves for @ $5 and they work SO much better than those cheapo disposable sewer gloves.
2. Check your hose connections. Really. Make sure they are SECURE. Don't ask me how I know!
3. Pull the dump handle of the black tank. Let the tank empty completely before you turn the rinser on.
4. Hook the hose up to the black tank rinse and run the rinser until the line runs clear water.
5. Open the gray tank valve and let it drain.
6. Close the gray tank valve, replace the cap, rinse your hose and let it drain before placing it in storage.
7. Put a liberal amount of hand sanitizer on your gloves and then wipe off with a paper towel. Take off your gloves and wash your hands (or at least use hand sanitizer).
Bob’s Tank Chemical mix
Equal parts of:
  • RV Digest-it (I have recently added this to the homebrew. It's a biologic and speeds the decomposition of toilet paper)
  • SuperClean (You can get it on amazon.com)
  • Liquid Calgon
  • Pinesol
    I usually mix up a couple of gallons at a time and this is usually good for a whole camping season. After every dump, I put 6OZ in my black tank & 4OZ in each of my gray tanks. Then add a gallon (2 gallons in the black tank) of water to each tank to get things started J
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-29-2016, 11:01 AM   #8
Dave Lyon's Avatar
X2. All I've ever used is 1 cup of Calgon and 1 cup of powdered laundry soap and dump in 5 gallons of water prior to leaving on a trip and let it work its magic.
I have no black tank odours. Calgon softenes the water and prevents solids from sticking to the tank, which should result in a well drained tank.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 06-29-2016, 11:02 AM   #9
DDC
DDC's Avatar
Been using the calgon and laundry detergent for a few years now and didn't have any problems, using it in the new trailer now to. I don't think bleach is a good idea as it "gasses" and will carry any orders with it.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 06-29-2016, 11:45 AM   #10
I go RV'ing not Camping
jgourlie's Avatar
I have been using the Blue-Streak system this year. I was using just the drop in packs last year and I had a bad smell all the time.
This year it smells like the baby powder smell of the blue streak all the time...so far I am loving it. Haven't filled my tank yet once so I haven't dumped it yet, but the smell is good.
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
