07-01-2014, 09:56 AM
Geo Method Results?
Hi All, have just purchased a Rockwood Minilite 2109s. Bought privately, unit is one year old and been used only 3 times. I have been studying the Geo Method of keeping the holding tanks clean. This is where you use water softener and Laundry detergent in you tanks to keep things smooth and prevent solids from sticking to the sides and the sensors. I was just wondering if anyone else has heard of this and if anyone is using this method. If so, how satisfied are you with the results?
07-01-2014, 09:59 AM
It is a widely known and well used method. I switched to it about 2 1/2 yrs ago and think it's much better than using the drop in packets.
2014 Sabre 34REQS-6
07-01-2014, 10:01 AM
I'm switching to it once I get down to a couple of drop ins left. I need to get off my duff and start it with my gray tanks.
07-01-2014, 10:02 AM
Plain Old Member
We use the Geo method, or the RV Digest It stuff by Unique.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
07-01-2014, 10:08 AM
We use the GEO system and have for a number of years and see no reason to change. Good Luck
2011 F250 CC diesel longbed RWD
2012 V-Cross 275 fiver
07-01-2014, 11:08 AM
Some folks use Dawn dish soap instead of laundry detergent, dont think it really matters. The Calgon water softener can be hard to find in some areas and some only have it in powder form, but it all works. Some will tell you that if you cant find Calgon to use Borax as it is more readily available. Problem I see there is that Borax is not a water softener, so will it be as effective in keeping the side walls of the tanks slick?? And although there are tons of opinions, I have yet to hear of someone crawling into their holding tank to check out how slick the side walls are with one vs the other.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
07-01-2014, 12:44 PM
Does anyone know if you have to provide proof of insurance to purchase a used travel trailer and plate in Ontario?
07-01-2014, 12:47 PM
You may want to ask that in another thread or post a new thread...its not all related to this topic.
07-01-2014, 01:09 PM
I started using the geo method about 5 camping trips ago. We are only weekend warriors and it made sense to me that the chem packets wouldn't be doing their job over the 2 or 3 days we use the toilet. I haven't noticed much of a difference, the black tank gauge still reads 3/4 after I dump, but I haven't done a real good tank flush yet. I add the Calgon and dawn dish soap along with 8-10 gallons of water before I leave home. I figure the sloshing during the drive will help.
Don & Kim
Willow Spring, NC
2012 Rockwood Ultra Lite 2604
2013 F-150 4x4 EB
07-01-2014, 05:26 PM
Geo Method
Vstrom
Add a bag or two of ice with some water in the black tank and see if that helps.
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 Chevrolet 4500
Using FR app
on 2012 4500 Chevrolet Chassis
Paul
07-01-2014, 05:37 PM
When we leave the campground, I put a cup of SuperClean, 1 cup of Pinesol and about 2 or 3 gallons of water in the black tank and about 1/2 that amount in the 2 grey tanks. Works great. Also have the Blue Streak on the toilet and use a mixture of 1 part SuperClean, 1 part Pinesol and 1 part water in the tank which disposes the mixture with each flush.
07-01-2014, 08:49 PM
Who Dares, Wins
We have the bluestreak and love it. I will need to remember this when we run outvof blue stuff.
2015 Chevy HD D-Max
2022 Impression 315MB
07-01-2014, 09:12 PM
Who Dares, Wins
I started this trailer, new, with the geo method. Went a few weeks before we needed dumping and still the tank read 3/4. A few fills with the hose and dumps it read fine after that. I will try it again and see if it is cumulative over time, but bought a flush king none the less for lots of water when dumping.
2015 Chevy HD D-Max
07-04-2014, 10:43 AM
how much water softener and detergent do you use for a 30 gal holding tank? thx
2014 Wildwood x-lite 185br
towed by 2013 Ram 1500
07-04-2014, 11:20 AM
Here's the scoop on the geo method from the Library:
Forest River Forums - Downloads - Geo Method
2011 Traverse LT, 3.6L, FWD
07-04-2014, 11:50 AM
Here is the Geo method site that I used to learn how to do it.
2014 Sabre 34REQS-6
07-13-2014, 04:21 PM
Where should we go next!
I've been using the "Geo method" for about 4 years now. Works great. However, about mid summer last year I started getting a bad smell when the toilet would be used.I use a "Flush King" and know that when I'm done dumping the water coming out is clear.
I tried dumping and back flushing repeatedly to no avail. I started reading around and I believe found an article from the same author of the "Geo Method".
His answer......use a little bleach once in a while. According to him, sometimes you get an over production of bacteria in the tank.
Dump the tank and back flush till it runs clear. Dump some bleach down toilet and back fill with water. Let it sit for 15 or so minutes and dump. Odor was gone instantly and haven't had a problem since.
Now I do this once mid season,and at the last dump of the season before it gets put away. Opens up in the spring with absolutely no orders.
Ford F-150 4X4 Supercrew Ecoboost
SportTrek 334 Touring Edition
Equalizer 4-point 10K lbs.
07-13-2014, 04:28 PM
Here is the article. Hope this helps you.
https://sites.google.com/site/cbruni/
07-14-2014, 07:17 AM
No you don't have to.
Been there, done that...lol !
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
07-14-2014, 08:02 AM
After reading this thread I am thinking about doing the following: at the end of each camping trip fill each tank with water softener and laundry detergent and use a garden hose to completely fill the tanks, then drain the solution in them just before the next camping trip. By filling the tanks completely the sensors would be sure to be cleaned.
