Old 10-02-2013, 02:10 PM   #1
GeoMag
I am wondering if anyone can tell me what the maximum PSI I should use(allow) when connecting my Sterling Wildcat 35LS upto the water faucets at RV parks?
geomag is offline   Reply With Quote
Old 10-02-2013, 03:36 PM   #2
Denver, CO
garbonz's Avatar
PEX plumbing in these things are rated at 60psi so I go to 55, using a good pressure regulator.
2017 Fuse 23T
Old 10-02-2013, 03:43 PM   #3
Denver, CO
garbonz's Avatar
CORRECTION.
Per the rvwaterfilterstore
You have it set up very well, although I would suggest that if you have it set at 45 like may be indicated in the picture, that you move it up to the 60-65 psi range. If the park has it, you will enjoy that much more performance out of your water system. Obviously, if you are too concerned about pressure in the RV, you may choose to leave it at a lower pressure. Your plumbing is rated at 125 psi, so half that should not be an issue. Of course, you may have it already set higher and the pressure at the park is only 45. Anyway, you are good.
SO the Plumbing is rated at 125psi. And 55-60 may be a good spot. In practice I have rarely seen it this high...
2017 Fuse 23T
