Old 05-03-2015, 07:50 PM   #1
muddyrode's Avatar
Girard tank less water heater will not light
I have a girard tankless water heater in a 2012 wildcat sterling we bought ,it last fall so this weeekend. Was are first time out we could not get the water heater to work when you turn on the power switch on the unit outside the red light does not come on but the exhaust blower fan does come on i have check all the breakers and fuse,s that i can find we did turn on the hot water in the sinks to try to get it to kick on if you look into the flame port there is no flame and we do have propane as the furance and stove work all weekend it like the gas igniter does not work any ideas
thanks
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 05-04-2015, 06:42 AM   #2
Oakman's Avatar
I really donít have much help for you. I would start the whole process over and see if it will heat the water. FYI the only time you will see a flame in the heater is when you have a hot water faucet turned on.
First turn the Girard off. Run water through all the faucets (both hot and cold) in your Sterling. I know youíve done this already, do it again. Now turn the Girard back on and then set the mode switch to HIGH. Turn on the hot water faucet that is physically closest to the water heater and let it run until you get hot water.
If you still don't get hot water turn the Girard off and wait 5 seconds and try again.
If you still donít get any hot water then I would suggest calling Girard directly at 1-866-559-1221
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-04-2015, 06:57 AM   #3
muddyrode's Avatar
thanks but i going to call them today as i must have trieds that 20 times over the weekend
thought if there was some unkown fuse i missed after reading the manual this it looks like it has to have 12V for the ingniter but i,m not sure what the blower fan take as it does work and come on, but the the red power light does not come on
I bought it thru a dealer and have 11 days left on my warranty
try to save the 120 mile trip to the dealer
Old 05-04-2015, 07:05 AM   #4
Oakman's Avatar
I hope Girard can get the water heater working for you. Let us know how things turn out.
Bob and Joyce
ATU Local 788
Old 05-04-2015, 10:18 AM   #5
Future Buyer
I have an Atwood tankless. Had a similar problem; no ignition & fan ran continously. There is a vacuum switch with a small tube that exits thru the access door to the outside. Tube got blocked with water. RV repair tech cleaned out tube, water heater started working. Hope this info helps.
IdahoBob is offline   Reply With Quote
Old 05-04-2015, 12:30 PM   #6
try this
I had the same problem with mine. My problem was a limit switch on the exhaust. After fan stop blowing switch was to flip back. It did not. If I moved by hand it worked again. So put one little drop of silicone on the arm of switch. Worked perfectly. Hope this might help.
lewdon is offline   Reply With Quote
Old 05-04-2015, 12:50 PM   #7
Mmnsc's Avatar
Have ypu tried pressing the reset button. When you look into the water heater, on the left side towards the back is a little white round switchthat has a button on the front. Try pressing that. It should lite after you reset the high limit switch.
Mmnsc is offline   Reply With Quote
Old 05-04-2015, 01:00 PM   #8
extremebike's Avatar
If this is the first time you are using the RV this year then you may want to try lighting the stove and make sure the burner lights all the way around. Air gets in the propane gas line and has trouble lighting.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 05-04-2015, 02:15 PM   #9
Micro swtch
We also had a problem with the exhaust micro switch and adjusted. Now it works but you have to use about 2 gallons of water before it gets hot.
Bones is offline   Reply With Quote
Old 05-04-2015, 09:05 PM   #10
We had problems with getting hot water until we learned to turn on faucet just enough to get heater to work. Let it go until the trickle feels hot then turn on the water more to get the temp adjusted. Used a lot less water. Also learned that the high setting worked great for all uses except showering. Then we use the low setting to maintain a better temperature.
heater, light, tank, water, water heater
