Old 01-22-2015, 12:05 PM   #1
Girard Tankless RV Water Heater
Hi, couple days ego I purchased Sandstorm F350GSLR TH 5th wheel. This trailer came with the Girard Tankless Water Heater. But when try to pick the trailer and go thru with service guy the water heater supply just I would say lukewarm water. I left the trailer there then and they will try to fix it. But was wondering, if somebody have any experience with those type of heater. Because flame inside the heater looks good, propane pressure good and we even try to hook on the city water to see, if maybe the water pressure is the problem. Honestly think it is good idea, just don't think will be preferable for dry camping. I even think switch to old style water heater with the tank, if will be possible, maybe electric wiring will be problem, because you really waste lot of water to wait for warm one. IMO
Which is funny from green perspective, save the gas to waste the water....LOL
milos
milosusa is offline   Reply With Quote
Old 01-22-2015, 12:26 PM   #2
Campin Cajun's Avatar
If yours is the gen II, it should have a dial somewhere in the camper to adjust the temperature.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 01-22-2015, 12:43 PM   #3
Yes it is generation II and have the dial adjustment in the bathroom. We even try to bypass it , but still the same. Only when we open the facet just a little bit we get hot water, but it is very tiny stream of water....
milos
Old 01-22-2015, 01:06 PM   #4
jonrjen's Avatar
You do understand that all air has to have been purged from the water lines including washer hook up, out side shower and every other faucet on the trailer. The water heater will not work unless there is a set amount of GPM entering and going through the water heater so water pressure must meet that minimum.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 01-22-2015, 03:47 PM   #5
Honestly to say, it is my first trailer with the tankless water heater, don't know that. But I assume service guys should know that.....maybe.
You need to do that all the time when trailer sit for some time or just in case water tank get empty and the pump suck air ?
milos
Old 01-22-2015, 04:00 PM   #6
jonrjen's Avatar
Service guy should know, but it wouldn't be the first time that they had no idea.
Every time you take it out after draining the lines and tanks you will have to bleed the air out of the water system. It's not hard to do, just open every faucet let the water run until there is no air left in the lines. But, like I mentioned you have to do every faucet even the outside wash station shower if so equipped.
You also adjust the water at the faucet by turning on the hot water then open the cold water to cool the water temp coming out to what is comfortable for you.
2013 Wildcat 353LS
Old 01-22-2015, 04:02 PM   #7
Thanks, hopefully that is only the problem.
milos
Old 01-22-2015, 04:15 PM   #8
jonrjen's Avatar
We had the 1st generation tankless in our Wildcat. We enjoyed the long instant hot showers. But, started having problems with it during the summer months. Seems that if the water coming into the water heater was too warm straight out of the ground it would confuse the sensor and not always trigger the water heater to activate.
We took the trailer back to Elkhart for some other services and made mention of the issues we experienced. They made a couple of phone calls and we were given the choice of a new generation 2 to be installed or a traditional gas and electric tank water heater. We chose the tank due to being able to use the electric mode to heat water without using our propane.
But along the way we learned a whole bunch of information on the tankless setup.
2013 Wildcat 353LS
Old 01-22-2015, 04:32 PM   #9
Yeah I play with the idea to maybe replace it with the conventional water heater too. I only do dry camping in the dunes and on my old TH I never had one problem with it. Plus we really don't take long shower, the gray tank get full fast if we do. I think will be no problem to exchange it, size of Gigard is pretty close to the Suburban water heater.
milos
Old 01-23-2015, 11:40 AM   #10
I had a Jayco MH with a tankless water heater. I think it was the same make and model. I didn't like it at all, mostly because it took too long to put out hot water, it was very noisy, and ran for a while after the water was turned off. Now I have a Coachmen Prism with an "old fashioned" tank, and I like it much more. It's probably cheaper too. Sometimes advances are steps backward
jeffrapp is offline   Reply With Quote
heater, tank, tankless, water, water heater
