Old 05-20-2013, 08:49 PM   #21
Herk7769's Avatar
Originally Posted by Grey9712 View Post
You are right. When the bypass is closed and I try to use hot water I get a trickle. I tried I the heater tonight with all valves open and I don't know how but I have hot water. Is it possible for this valve to have been installed the wrong way?
Not sure. Can you take a picture of it?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-21-2013, 06:59 AM   #22
rattleNsmoke's Avatar
Like the pics Turbs sent, all three handles should point the same direction for summer operation.
rattleNsmoke is offline   Reply With Quote
Old 05-21-2013, 07:55 AM   #23
Herk7769's Avatar
The bypass must be closed to route all incoming water from the open cold through the water heater to the open hot water outlet.
Leaving the "middle" valve open (same orientation as the inlet and outlet valves) will add cold water to the hot water coming out of the heater resulting in uneven showers and warm (not hot) water.
Unless you mean all level with the ground?... Not all heaters have those kind of valves.
Old 05-21-2013, 09:37 AM   #24
If I do this it will burn up my hot water element. I understand what you all are ssaying but NO WATER GOES TO THE HOT WATER HEATER WHEN THE VALVES GO IN THE SAME DIRECTION.
Grey9712 is offline   Reply With Quote
Old 05-21-2013, 12:37 PM   #25
Yeah all parallel to the ground.
Old 05-21-2013, 12:57 PM   #26
Arefbee's Avatar
OK, three valves, two open (inline with the pipe) one closed (on the bypass). All three will be parallel to the ground -O when positioned right.
Next, open a hot water tap to let water into the WH. Give it time - eventually it will come out the tap.
If water still does not go into the heater, go back along the line - is it going into the fresh water tank instead?
Not to be insulting, but is the drain closed?
2011 PrimeTime Tracer 2600rls
Arefbee is offline   Reply With Quote
Old 05-21-2013, 12:57 PM   #27
TURBS's Avatar
Ok we seen something like this last year.....
Pull your valves out and make sure there opening and closing.
The guy last year had the knob turn but the insides were not.
Old 05-21-2013, 02:20 PM   #28
I will have to try that. I'm thinking the valve on the red line(hot water) would be the one not changing because water works on cold all the time but not hot when the bypass is closed. Do i just pull the valve handle off?
Old 05-21-2013, 02:46 PM   #29
TURBS's Avatar
I believe you'll have to remove whole valve.
Mine have nuts on either sid belive but yours may have squeeze clamps that have to be cut off and then worm clamps to replace them.
Turbs
Old 05-21-2013, 02:50 PM   #30
I think I'll have the dealer take a look at it. I do have hot y water right now so I'm happy for that but I do want this fixed.
Old 05-21-2013, 02:52 PM   #31
TURBS's Avatar
Please let us know what you find!
Old 05-21-2013, 02:54 PM   #32
Denver, CO
garbonz's Avatar
Whew, this is hurting my brain
2017 Fuse 23T
