Old 10-19-2015, 06:01 PM   #1
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Got to cut supply lines....
Need assistance from experienced RVers who have cut water lines..... Getting ready to install another faucet at the bathroom sink and I will need to shorten the supply lines....once I cut these, what can I get at Home Depot to re-attach the fittings that thread onto the faucet???....Help appreciated.
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 10-19-2015, 06:08 PM   #2
Who Dares, Wins
doc73's Avatar
Most use the shark bite fittings from HD. Do you need to cut the lines? When I changed my faucet I was able to just finagle them in place.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 10-19-2015, 06:14 PM   #3
When I removed the old set, the lines were extremely tight... the new faucet is a much better Delta faucet and drops down about another 2 inches inside the vanity....as stiff as that supply line material is, I don't think I can get away with that much bending.
Old 10-19-2015, 06:28 PM   #4
onetonford's Avatar
I bought the fittings rings and tool at home depot but the tool was very expensive and I have used them for other jobs so for me was OK. the 1/2 inch is what works and I have no leaks....
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 10-19-2015, 06:38 PM   #5
Scubanut's Avatar
Maybe you can get away with adding a flexible water line. There is all kinds of adapters you can get at Home Depot or Lowes.
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 10-19-2015, 06:38 PM   #6
Left Coast
If you use Shark-bites, get the plastic release tool for future removal (cheap) Also, if your handy with side cutters, the crimp clamps could be used......I've got a pair with the cutting part 90 deg. to the handle
Old 10-19-2015, 07:14 PM   #7
Iwannacamp's Avatar
Lowes has a set of crimp pliers for about $30...or Amazon of course. I bought a pretty good assortment of pex style fittings. I think I am ready when repairs or mods happen. I am installing a drinking water filer/faucet as we speak. The clamp type is what I chose. My crimpers are Apollo.
BTW Home Depot wanted $65 for a similar set of crimpers.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 10-19-2015, 07:21 PM   #8
nomad297's Avatar
Jus get two 1/2" SharkBite couplings, cut each of the lines in an easy location, connect them to the new faucet and couple the two pieces back together with the couplings.
Bruce
Old 10-19-2015, 07:42 PM   #9
Thanks to all for ideas....will not be an issue.....always enjoy being able to rely on this forum's experience.
Old 10-20-2015, 12:22 PM   #10
Telstar's Avatar
The cutting tool for schedule 40 sprinkler pipe works fine with PEX. Get the push on fittings if you can find them, otherwise use the ones with the righting ring.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
