Old 02-17-2016, 10:11 PM   #11
Originally Posted by Tiggerdad View Post
The cold water line appears to be pushing on the hot water line and stressing the connection at the nut or a possible crack in the fitting.
I think Tiggerdad is on to something, all of the pipe, fittings and probably the faucet are plastic, it does not take much stress on them to make a leak. It may be the water getting hot is expanding the pipe enough to open the leak up, ether cracked fitting or faucet, or even loosening a fitting. I would remove the pipe and faucet and and look for cracks on both, then reinstall with the cold pipe to the back away from the sink bowl to keep off the stress. I have seen many weird water leaks in my 30 years of plumbing so all i can say is,
Happy camping.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is online now   Reply With Quote
Old 02-17-2016, 10:37 PM   #12
Fulltime family RVer
You need to get those two apart and somehow see/feel above to find the source of the water. You've found a symptom, but not your actual issue.
Keep contortionisting.
ependydad is online now   Reply With Quote
Old 02-18-2016, 12:46 PM   #13
Kels4g's Avatar
So last night, we messed around with it a little and my husband turned something (because you can't have your arm and your eyes in the cabinet at the same time lol) and the leak is now much less than it was before but still a slight leak. He will have to do whatever he did last night again tonight and hopefully the leak stops.
Kelly and Stephen with Daisy, Lily, and Roxy!
Run Free Sweet Riley 2009-2015
Visit our blog for more information and details!
www.kels4g.com
Kels4g is offline   Reply With Quote
Old 02-18-2016, 01:09 PM   #14
B and B's Avatar
You nailed the issue you said only happened when hot water is on. The facet nut washer is not compressed enough, when hot it shrinks and leaks. Tighten it when hot. Hand tight, as tight as you can make it should work. As others said separate the line as well, could be the cause of misaligned fitting.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 02-20-2016, 10:18 AM   #15
Kels4g's Avatar
Will try this today. Thanks!
www.kels4g.com
Old 02-20-2016, 12:44 PM   #16
Kels4g's Avatar
I think we fixed it! We can't see anymore water leaking and the water seems to be staying hot too! Will be taking a shower soon to confirm. SO excited!
www.kels4g.com
Old 02-20-2016, 01:13 PM   #17
And you fixed it how?��
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 02-20-2016, 04:13 PM   #18
Kels4g's Avatar
We let some water out through the relief valve on the outside portion of the water heater. Under the kitchen sink, we hand tightened something until it just didn't leak anymore. I don't know what we hand tightened though bc we can't get our head and arm under there at the same time to see while we are tightening.
www.kels4g.com
Old 02-29-2016, 05:50 PM   #19
Kels4g's Avatar
We have fixed it! Thanks everyone who responded.
The leak was a matter of the connectors for the hot water line not being tightened enough.
The hot water being lukewarm was because the bypass valve was not fully opened.
As this time, both issues are 100% resolved!
www.kels4g.com
Old 03-01-2016, 12:36 AM   #20
Thanks for letting us know, glad your good now.
Dale & Karen
leak
