Old 08-15-2015, 08:29 AM   #1
Gravity fill for water tanks
Good Morning
Enjoying our new Georgetown 310DS but notice that there is no Gravity Fill for the water tanks. When I am ready to Winterize, how or where to I get the antifreeze into the tank. With my old motorhome I would pour in the gravity fill and the pump through the system. In reading some of the posts it states there may be a suction hose on some units. I cannot locate it. Does a 310DS have such an animal.
Thanks for your help
Terry
cubsandcoltsfan is offline   Reply With Quote
Old 08-15-2015, 09:42 AM   #2
waiter21's Avatar
I have a 2001 Mirada, so yours may be significantly different.
I have no gravity fill either, but I can set the water panel valves in a certain position, then use the water pump to suck water (or antifreeze) into the tank.
WINTERIZING / DEWINTERIZING | 2001 Coachmen Mirada 300QB
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-15-2015, 10:10 AM   #3
Ford Idaho's Avatar
My unit came with a winterization setup did yours?
I hook this tube.
to the black capped inlet, switch the valves and use the water pump to winterize.
I do NOT put antifreeze in the water heater or fresh water tank.
tank, water, water tank
