Old 08-06-2012, 08:16 PM   #1
Gray and galley tanks
I have a 2013 Salem 32bhds. It appears that my kitchen sink, shower and bathroom sink are draining into my galley tank. The outdoor kitchen sink is the only thing draining into my gray water tank. Is this normal?
salem 32bhds is offline   Reply With Quote
Old 08-06-2012, 10:11 PM   #2
Sounds normal in a way. Must have 3 tanks, 2 gray, one black. The galley and the gray are all gray water, so pretty normal. The only thing in the black tank is the toilet, on almost all models.
And WELCOME by the way.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-06-2012, 11:51 PM   #3
The problem I am having, is my galley tank is filling after two showers and 1 load of dishes and my gray tank never fills. It seems to me that the shower should be draining to the tank with the outside kitchen sink? They tell me that each tank holds 35 gals? I had a smaller camper with smaller holding tanks before and never had this issue. I thought the galley was for sinks and the gray was for the shower?
Old 08-07-2012, 01:29 AM   #4
showtime0022's Avatar
Are you sure there full or just a bad probe? I had same problem, on of the probes installed wrong. Dealer installed a new prob at a different height. It works alot better now.
showtime0022 is offline   Reply With Quote
Old 08-07-2012, 06:11 AM   #5
Herk7769's Avatar
Depending on the length of your showers, this could be correct. A "normal" shower can use a lot of water even with the low flow restrictors used in RVs.
"Navy" showers will work a lot better with a 35 gallon tank.
Troubleshooting the MicroMonitor
I am dealing with a "crudded" up tank now.
This is not an "indicator" problem but a dirty tank problem.
HAM CALLSIGN - KC3FFW
Old 08-07-2012, 06:29 AM   #6
Hey,the Navy has a lot more water than the USAF! Youroo!
Old 08-07-2012, 06:34 AM   #7
Herk7769's Avatar
UGh, it is salt water. Fresh water in a Navy ship is a luxury beyond price; they tell me. The Holiday Inn has plenty of fresh water for the Air Force.
An Army shower means you use clean mud, I am told.
Old 08-07-2012, 08:42 AM   #8
Thanks everyone for the post. I know the tanks are full because they are not draining into the tank after it reads full as the water is staying in the shower and kitchen sink. being as the kitchen sink and the shower are the two most used items in a camper i think it would make since that they go to diffrent tanks?
Old 08-07-2012, 08:46 AM   #9
Any chance you can get under there and plumb the two together? I found room under my TT (much better now).
Bryant, Kristin, Elijah & Joseph
2012 Puma 30KFB
2006 2500HD Duramax
n2_hunter is offline   Reply With Quote
Old 08-07-2012, 08:52 AM   #10
Looks like you are going to have to learn real fast what "less water is more" is all about. Wet yourself down, shut water off, soap up, turn water on, rinse off, turn water off. Dishes - Little soap water in the sink, wash dish, rinse shut water off, repeat. These tanks are not that big. Only other thing you can do is always get a full hookup site and keep dumping but make sure you fill back up before you want to dump your black tank for rinsing purposes.
2013 Puma 30DBSS (Parked at Seasonal Site)
2001 Ford F-150
travyp is offline   Reply With Quote
