Old 07-10-2016, 12:02 PM   #1
Cummins Retired
Gray/Black Tank Gauges way Off
Finally after continually complaining about our Galley/Gray/Black tanks filling up way too quickly for the umpteenth time, I decided it was time to confirm my suspicions about tank levels being way off. Simply amazing how far off the gauges are at 1/3 and 2/3. Who would have thought it?
Galley Gray Black Fresh
Empty 0 gal 0 gal 0 gal 0 gal
1/3 1 gal 2 gal 2 gal 3 gal
2/3 8 gal 8 gal 13 gal 14 gal
Full 24 gal 24 gal 30 gal 25 gal
Capacity 30 30 30 38
This is ridiculous. My 8 year old grandson could come closer to knowing where to put a sensor for 1/3 and 2/3. When will the RV industry start building quality into their products??
2010 RAM 2500 w/Cummins Diesel, 4.10 axle
2015 PrimeTime Tracer 250 AIR
2105 nights camped = 32
2016 nights camped = 14 nights
2016 planned = 34 more planned!!!
tommybill is offline   Reply With Quote
Old 07-10-2016, 12:27 PM   #2
Georgia Frog Rally 2017
aceinspp's Avatar
Not so much as where the sensor is but if it gets tt paper hung up and a lot of crud from gray water that they get covered which cause erroneous readings. Maybe some day they come up with a better idea but then cost more to do. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
aceinspp is online now   Reply With Quote
Old 07-10-2016, 12:29 PM   #3
Flybob's Avatar
On at least some of the tanks, the issue could be that there is some liquid in the tank after the drain stops draining. You are assuming that when the tank stops draining, there is "0 gal" in the tank. For the FW tank this is many times not the case. Ie. If there is 8 gals in the FW tank when the drain stops, then the readings are very close to correct.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-10-2016, 12:29 PM   #4
TURBS's Avatar
Some day you'll not even look at those worthless gauges and just "know" when it's time to dump.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-10-2016, 12:30 PM   #5
Oaklevel's Avatar
I wish they would stop putting gauges on the tanks ...... The few years that they have been used on the tanks they have been problematic. I know how long ours takes to fill so I don't use the gauges. The tanks are usually smaller on one end and deeper on the other to drain so its is not an easy task to get them right.
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 07-10-2016, 01:38 PM   #6
Mr Havercamp's Avatar
Get this
https://youtu.be/-kttyNVuVEI
2017 Roo 23WS
2015 GMC Sierra 2500HD 6.0 DCLB Z71
Mr Havercamp is offline   Reply With Quote
Old 07-10-2016, 02:02 PM   #7
Cummins Retired
Thanks for the replies. I tipped the camper every which way to make sure they were empty, then when I filled them, I was able to add as much water as the tank capacities were. So, fairly sure there was no residual liquid in the tanks. Just amazing that for 1/3 full, it only took a couple of gallons in a tank, even the fresh water tank. I'm posting a small chart by my indicator lights for reference. Normally we would never get to the max, but heading out for 30 days in September so, will be dumping along the way.
Tom
Old 07-11-2016, 12:13 PM   #8
Head Rambler
The issue is that they measure 1/3rd as distance, not volume. 1/3rd the way up a sloped bottom tank isn't very many gallons. Especially when the sensors are on the tall end.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-11-2016, 12:46 PM   #9
Once a year Usually befor a longer trip, I fill my black tank with ice and a scoop of powdered laundry soap. As the ice melts it sloshes around in the tank and cleans the sensors. It does not make them correct but it dous clean the tank and sensors good.
Hamilton is offline   Reply With Quote
Old 07-11-2016, 12:51 PM   #10
OMG! How much ice does it take to fill your black tank?
wildcatmlm is offline   Reply With Quote
black, black tank, tank, grey water
